POCO X3
eip1234
How is this phone compared to Note 9 Pro? Specs look quite close
They are largely the same, yet with minor differences (to me). Their pricings are similar too.
Poco x3 wins:
> Screen 120Hz
> Louder speakers with stereo sound
> Slightly faster cpu
> Bigger MP selfie, wide-angle camera
> Dual LED flash
> Slightly bigger battery
> miui update seems to be faster
Redmi note 9 pro wins:
> Slimmer and lighter
> 2 sim + MicroSD
> Bigger MP macro camera
Ye_Rongtian
My set bought from 9.9 so far nv experienced this, but sometimes when scrolling in chrome, chrome will freeze, tap home and then go back to chrome again then working again.
Freeze when scrolling in chrome is android webview thing. Nothing to do with Xiaomi. All those using android and chrome will experience this. If you do not want it to happen, use Firefox or other browsers which is not based on chromium.
Ye_Rongtian
anyone tio yellow tint bug?yr phone screen will suddenly become yellowish. happened when using chrome ..need to toggle reading mode on off become normal back..
Sent from POCO X3 using GAGT
Your display color scheme set as auto?
Ye_Rongtian
If want to consider this x3 vs note 9 pro, I can tell you the faster touch sampling rate on the x3 alone is a winner. Plus the stereo speakers...
If you text a lot, you can tell the difference.
rECKleSSfElla
Qoo10 delivery working overtime. Just received delivery for my 128gb Blue set bought frm Goldfinch.
Ye_Rongtian
b4 yes..change to manual same problem..now after change the chrome setting no more tint yellow liao..
Mine didn't change to yellow tint after manual setting on 12.0.3.0... now I enable reading mode all the time so didn't test again on 12.0.4.0 :s13:
DaRRenLieW
Ok my 11.11 hoot x3 from shopmeee is finally here . 10 days !
$258 tsktsk
Sent from Samsung Note 20 Ultra [SD] using GAGT
oddbasket
So is android? Have never experienced this previously, probably my phone on older android version previously cannot compare.
Ye_Rongtian
Yup. Samsung, Oppo, Google Pixel, Asus all have it. Go search the web and you will find plenty of people talking about it. Here's just one of the many threads.
https://www.reddit.com/r/chrome/comments/hj6fbo/when_google_is_going_to_fix_chrome_freezes_on/
i1magic
Main difference as compared to Redmi Note 9 Pro are :
1. Cpu 732G vs 720G
2. Battery
3. 120hz screen
4. Hybrid SIM vs dedicated microSD card slot
That's about all the main difference, correct?
