POCO X3
eip1234
As I don't play video games so I adjusted the screen refresh rate from 120 to 60, after a week's usage at 120. Immediately i feel that the phone overall becomes more snappy and responsive ... Even webpages seem to load faster.
Any explanation to this? Anybody has the same observation?
justln
The problem is that Poco only has 90 hz max and not every app supports it, especially most browsers.
I can just say it's a placebo effect, you happy can liao.
Aresden
Shipping on delivery, details: haven reach export-warehouse in China yet. Maybe Sunday no updates.
how do u c the details? under shipping info i dun have any tracking number
Actually I also "confirmed delivery" early to get the grabpay cashback, any1 like me?
matrix05
Using PC, under shipping delivery tab, there is a shipping info tab. From last week till now, stuck at Transit to the Dispatch Center, no movement. Maybe got problem liao. Seller is Goldfinch.
kazuki666
Anyone here is switch from F1 to X3? Like to know the experience...
By the way, the goldfinch set, has anyone tested app
Singpass
Banks like posb/ocbc
I need to use these apps very often, so scare will have problems.
Sent from Xiaomi POCOPHONE F1 using GAGT
decibels
Singpass
I feel x3 is not as snappy as my f1, got abit of laggy feel when using certain app (eg GAGT, YouTube)
Will monitor a few weeks to see how, might go back to f1 or upgrade to f2 if the price is reasonable
Bought from Goldfinch, all the apps u mentioned above can be used, no issue
Chisaigyu
Anyone have "mi video keeps stopping" issue with the gallery when viewing videos? Tried to clear data and reboot but still have the problem.. Thanks!
eip1234
Likely the lag is due to the 120 refresh rate of screen. You can set it to 60 and try... Let us know how it goes...
divineone
Is this seller reliable? Any feedback :s11:
Is $309 price ok?
the price can apply q10 cart voucher, so look out for it. ordered recently, will receive in slightly under 2 weeks, item is very well packed, the phone box is encased in those cushion bubble bags
Pryson
The laggy or stuttering is due to the software keep going back to 60hz then to 120hz. If you want smooth. Use setedit app and adjust the fps to fixed at 90fps. I did mine and now I'm on constant 90hz. Buttery smooth. Try it if you need it. 120 constant will exhaust the battery hence I use 90hz
a4973
May I know the MIUI for the poco x3 nfc is it same as the MIUI for the rest of the xiaomi & redmi phones ie full of bloat & ads ? Thanks
twosix
this is the global version. the latest version is 12.0.4. unless u r using xiaomi's apps, i dun see any ads at all. u also dun have to use xiaomi's apps since google and 3rd parties have many similar apps available in the google play store.
so no... i do not see any ads most of the time using this phone.
a4973
Thanks for the reply. The amount of bloat ware is still the same? Also size wise, I'm currently using Mi A2 am now considering pixel 4a vs Poco x3 nfc. I understand Poco x3 nfc is bigger but how unwieldy is it actually vs the mi A2? Thanks
twosix
my first xiaomi, nothing to compare to.
matrix05
Starting Delivery to the Destination Country
Starting Delivery to the Destination also. Looks like on the same plane. This is good news because no lost in China warehouse excuse. 1 wk passed, item not received yet = those who buy from HK (maybe is drop ship from China) must have the patience.
a4973
Was this ordered via goldfinch on qoo10? Thanks
