POCO X3
justln
Thanks for the reply. The amount of bloat ware is still the same? Also size wise, I'm currently using Mi A2 am now considering pixel 4a vs Poco x3 nfc. I understand Poco x3 nfc is bigger but how unwieldy is it actually vs the mi A2? Thanks
It's thicker than most phones but still "holdable" for me by using a phone ring. Length and width wise still ok.
Bloat and ads can easily be removed with a PC program if you don't mind using other apps instead of Xiaomi ones.
yusoffb01
yusoffb01
May I know the MIUI for the poco x3 nfc is it same as the MIUI for the rest of the xiaomi & redmi phones ie full of bloat & ads ? Thanks
1) all the adz can be closed just untick show recommendations
2) if cannot close you can remove the app and use free alternative
https://github.com/Szaki/XiaomiADBFastbootTools/releases
3) If you dont want to remove the app, u can remove wifi/4g access so ads do not load
a4973
Thanks for all the info. I use practically all Google's apps hence my current mi A2 and considering pixel 4a. Now also looking at bang for buck performance so looking at Poco x3 nfc. So as long as I don't want to use any Mi's apps I can run the debloat and thereafter it will be close to stock Android except for the skin? Thanks again
Squaredot
the price can apply q10 cart voucher, so look out for it. ordered recently, will receive in slightly under 2 weeks, item is very well packed, the phone box is encased in those cushion bubble bags
Thanks for your feedback.
Oh ya! Can use the $30 cart voucher this weekend :D price will be $279 :D
DaRRenLieW
I receive mine seal on 21nov till now I haven touch it. I like how it is seal hahahahah....
Sent from Samsung SM-N9860 using GAGT
Ivanka
Hi all, my poco's bluetooth keep on off by itself which is very disruptive to my music. Does anyone face the same issue?
LoneTraveller
Do u mean u keep losing connection to your Bluetooth headset? If yes, someone in one of the threads did mention something about tracetogether apps disrupting your connection with all the Bluetooth being on together.
I also have this issue on and off but I don't really listen to my earphone that much.
justln
No, try enable developer options in settings and tweak with the Bluetooth audio settings.
Ivanka
You are right! The disruption stops after uninstalling the app. Thanks!
osmond19
Mine's ordered via goldfinch:
Starting Delivery to the Destination Country
I received the update on Monday saying "[SINGAPORE CHANGI]
Arrived at Destination Country Customs" but just now I got an email saying the parcel was lost on its way and now they are refunding... Means what?
DaRRenLieW
Wow.. even gdfinch also chu pattern. My friend from shopmeee also same thing. Order on 11.11 then come 25.11 say lost and refund
Sent from Note 20 Ultra Snapdragon™ using GAGT
a4973
Maybe the sellers realize that they are selling too cheaply and out pattern?
