Oinkize
- May 22, 2009
Yours is considered as global set...how you tell is a EU set ?
mine is 12.0.8.0(QJGMIXM)
It's a decent phone. Almost all performance can match except the camera.looking at poco x3 pro, 8g ram with 256g to replace my mate 20 pro.
first time using xiaomi phone, any advise?
You can try Carousel else wait for 6.6 in you are not in a hurry...thank you, any good place to purchase one?
i saw the cheapest was $388 at shopee with local warranty
Should b good priceGot Poco X3 Pro @ $260 on Qoo10. Considered okay price?
Any 3A cable will dofor fast charge cables what brand you all recommend ?
Nope. Mine don't feel bended. How did you keep your phone with you? Which pocket etc...Anyone encounter the whole phone bended after few months of usage? i Bought the Poco X3 NFC for my 14 yr old son and after 3 months, the whole phone was bended and unable to charge. Upon bringing in to the repair centre in Funan, they discovered that the board in the phone had crack. I can only accept that it is case of misuse but is the body of this phone so fragile?
He kept it in his side pocket. But admitted he dropped a few times on the floor.Nope. Mine don't feel bended. How did you keep your phone with you? Which pocket etc...
Hmmm, icic. There could be reasons that it is caused by non manufacturing defect due to drop even with casing.He kept it in his side pocket. But admitted he dropped a few times on the floor.
did your son carry it around with casing ?Anyone encounter the whole phone bended after few months of usage? i Bought the Poco X3 NFC for my 14 yr old son and after 3 months, the whole phone was bended and unable to charge. Upon bringing in to the repair centre in Funan, they discovered that the board in the phone had crack. I can only accept that it is case of misuse but is the body of this phone so fragile?
I bought 369.. so its a good priceShould b good price
I forget last time how much liao
thx i also wana use the original but i dont think xiaomi sell it correct me if im wrong need spare cable xDUgreen or Anker cables? Hahaha. Actually just use the original cable will do. Safest.
