POCO X3
ahfish22
does yr guys gpay work with paylah or paynow?i try to scan not working..
Sent from POCO X3 using GAGT
try Settings -> Connection & Sharing - >Secure element position -> HCE Wallet
i use singtel dash for public transport and payment.
ahfish22
Those using nfc for buses especially, do you face issues tapping in/out sometimes?
The ezlink reader doesn't pick up the nfc signal at times.
rathalos
I'm using daily for bus, never face any issues.. in fact it picks up my phone like 3-4cm away from the reader..
Ur NFC antenna is located at the read camera bump.. u might wanna reposition the way to tap..
ahfish22
Most of the times it's OK.
But sometimes I have to literally rub the camera bump on the ezlink reader.
When it doesn't work. I'll have to switch to the other reader on the bus
kottty
still not working
ahfish22
still not working
My bad. Thought u referring to nfc issues.
Could it be some permission issues?
Or some dirt on your camera?
Lemme try paying via QR code on paynow and get back to you.
I tried a few times topping up grab pay credits using the QR code via PayNow. No issues though..
Shutterbox
Guys, do u have problem disabling authorization n revocation?
It works for my other xiaomi phones, but not x3. Is it because it's running miui 12?
Nakedtoes
:s13: wa lau 2020 liao people still blindly listen and believe all advertisement? just shows how lazy this people are, want cheap want flagship dont see the spec-sheet see if it fits their needs after that compare with flagship phone say slow :s13: just like the guy who did the review :s13: damn joke
That's why I got the k30pro zoom to surf net.. Confirm no lag
kottty
ya.i just try for grab top up no problem me too..
DaRRenLieW
You paid $300 and expect $3000 phone soft and hardware. Might as well try to see if you can fold the phone in half ?
Sent from HUAWEI MATE 20X using GAGT
wongminmin
Bought this SP.
Its smaller than the factory one.
Comes w a hole for the selfie cam, so that's gonna be a dustrap.
Decided to stick w factory one.
The supplied phone case looks sturdy n very snug fit. The side wall is taller than the screen, so if drop face down, proly will protect ok.
First impressions not bad, quite responsive for my needs. One hand ops better than what I think.
How to set up the phone w NFC so that I can associate credit cards with my phone to start paywaving n take public transport ah?
i bought from this seller too.... black 1....small. same seller transparent fit nicely. :D
jimlwk
Y buy k30 pro zoom instead of poco f2 pro? So far the only advantage is its OIS, right?
Somemore it's about $150 to $200 more ex than f2 pro, china rom and also no local warranty.
Nakedtoes
Yes because of OIS..
justln
Uh, need more info and elaboration. Had no issues doing those.
Shutterbox
Repeated the steps.
This time all can disable.
Before keep disabling for mca n miui daemon all cannot.
Now install grab, app cannot load. Dunno why
justln
Repeated the steps.
Can try debloat fastboot uninstall Xiaomi apps if you're not going to use them, reversible anyway.
tanchoo1
Repeated the steps.
Need to enable your GPS, open Google maps, go outside or next to your window and get a proper GPS lock.
Then grab will work.
Grab is a shtty app.
