POCO X3
xenocide
tks! Loving my X3 so far so good. :)
yes i'm also liking this phone
use it to play OnePiece and Bleach so far so good.
i am using it with xiaomi airdots S.
I find the volume a little soft. i have to turn it up to about 80% to get decent volume
Asus80
poco x3 have wifi calling or not. because i using note 9S dont have wifi calling. only VOLTE have
EveMuffins
I'm a light user. So far use it for GAGT, Instagram, YouTube and surf net only..haven't use it as my main phone as haven't buy flip case so not bringing it out.
ahcalvin
Still waiting for this case. battle tested on my other phones... cheap and good
Ralphel
If just simple debloat then no need fastboot mode, just connect. Try following the FAQ & Troubleshooting, you probably don't have adb drivers installed or something.
Shopee has the Nillkin POCO X3 NFC Slide Camera Cover if anyone needs it.
https://shopee.sg/Nillkin-POCO-X3NF...r-Phone-Protector-Case-i.209451787.5854536466
https://shopee.sg/Nillkin-CamShield...-Case-For-Phone-X3-NFC-i.298870551.7154009408
any bro bot and received this case?
can share teh real life pic of it on your phone?
jimlwk
Works normally? Good... I thought of getting a 512
On paper, xiaomi states up to 256gb i believe. Better check properly first before buying 512
Hybrid SIM slot, nano-SIM + nano-SIM or microSD
Up to 256GB expandable storage
Supports dual SIM and dual VoLTE
