POCO X3
Shutterbox
Need to enable your GPS, open Google maps, go outside or next to your window and get a proper GPS lock.
Then grab will work.
Grab is a shtty app.
Try the same install on poco f1 also indoor.
No issues.
Not sure if its miui 12 giving the problem
asthio88
Can someone help with ADB/Fastboot tool? I am stuck in 'looking for devices'.
I followed the instruction in GitHub; have enabled both USB debugging and install via USB, file transfer is on but still no luck. Did I miss anything?
Thanks...
jimlwk
Thanks...
Think your device have to be in fast boot mode by holding vol down and power button together until it resets to the mode.
justln
If just simple debloat then no need fastboot mode, just connect. Try following the FAQ & Troubleshooting, you probably don't have adb drivers installed or something.
Shopee has the Nillkin POCO X3 NFC Slide Camera Cover if anyone needs it.
https://shopee.sg/Nillkin-POCO-X3NF...r-Phone-Protector-Case-i.209451787.5854536466
https://shopee.sg/Nillkin-CamShield...-Case-For-Phone-X3-NFC-i.298870551.7154009408
t13
Does Shareme clone the entire phone over or just transfer apps, files, photos?
Warlock86
ccloh
no need to be in fastboot mode, i did so many times uninstall and reinstall back when phone in power on mode. since you can bring up the XiaomiADBFastbootTools meaning you have the correct Java SDK install so that remove from the equation. ADB tools install ? enable developer option and on the USB debugging mode is probably the next check you can do. if those are done try this
1. made sure the usb cable can do data transfer and not just power charging else won't work. you will know when there is option pop up asking you file transfer or charging only.
2. brings up the XiaomiADBFastbootTools then connect using a data transfer usb cable from the pc to your phone with usb debugging mode enable
3. if #2 can't, connect up the pc and phone first then bring up the XiaomiADBFastbootTools
if all 3 still can't i also don't know what to do haha
btw debloat is just to remove those list from your phone as it is not physically remove the apk so won't free up storage space. to physically remove the apk to recover some storage space you need the other method. one thing about debloat is if later on, you find that you need that feature, you can reinstall back via the XiaomiADBFastbootTools
Shutterbox
Can give links to a workable xiaomiadbfastboot tool n java sdk?
Tried a few versions and they don't work.
ccloh
mine is XiaomiADBFastbootTools version 7.0.3 (should be the latest) and Java SDK 14.0.2 with 15 being the latest. you can try this link
https://github.com/Szaki/XiaomiADBFastbootTools/releases
btw do you have adb.exe install ???? another possibility is are you connecting the device to the direct usb port of pc or through some usb hub ? might make a difference.
Shutterbox
I'll try these out. Thank you!
Nuclear Boy
Install the ADB driver if you haven't. Not sure if the tool helps you install before first run though. I did it manually before running the tool.
EveMuffins
Is the screen protector closest to the factory SP called hydrogel SP? My factory SP got a lot of fine scratches, caused by the chipped skin on the back of my thumb and index finger. :s22:
Want to replace it with soft film instead of tempered glass since glass may have white borders.
xenocide
yes correct.
