Poly Laptop Roadshow
ZrE0_Cha0s
Autocad , autodesk , grants ces , stat graphics
Autocad and autodesk 8GB is more than enough unless u do 3D modelling.
grants CES (no idea whats that)
statgraphic same as autocad 8GB is more than enough
ashhong
the weight.... Not easy to carry books + 2.5kg laptop to school everyday.
Don't bring books. I only bring my laptop w/o charger to sch for my whole poly and uni life.
Even then try to cut down to below 1.5kg, mine 1.58kg i still feel heavy after a while.
imshleep
Stupid qn but im going nyp also and i want to get the FX553 too. But how u buy from the rp one? Is it every poly have or do u have to go the rp one physically to buy? Also are u going to nyp to configure it?
Bilal N
Y go rp? Nyp will also have laptop roadshow wat...
Jedixx
Wah how u survive whole day without charger?
U got one of those 10hr battery life laptops?
Jedixx
I'm waiting for the nyp roadshow. I'm just referring to the Rp site as nyp has not updated theirs yet. We have to wait for nyp, sadly :sad: .
p.s. what course are u going to?
Keith Chan
I think all the poly offer the same brand and model laptops... so maybe you can use other poly website models as ref
Jedixx
Actually now i'm thinking of buying the GL553 instead of the FX553 because of aesthetics.
I don't really like the look of the FX553.
Compared to the GL553
However if I decide to get the GL553, I want to replace the 1TB HDD with a 250/500GB SSD(most likely going to buy from it show). Anyone think that's a bad move?
ZrE0_Cha0s
Well u are more or less forgoing the extra 1 year warranty offered by the school though and the 3 yrs omsite support they provided. But if u know how to replace the system without tampering the warranty syickers(if there is) and change. U can do that. But if u bought from IT show. Some ppl say that those ppl who help replace or upgrade usually end up damage the warranty stickers. But still depends on the company.
RiceGrain
Just gotten the FX553, performance wise is really solid. But the battery performance is very disappointing, 3~5hr depending on usage, Which is common for gaming laptop
Jedixx
Can you take pic and post here?
Online has little to no info on the FX553.
Jedixx
I will replace it myself, my poly roadshow is after it show.
Plus the user manual includes a "upgrading your laptop" section, so i'm pretty sure warranty will not be void because of that. Please correct me if i'm wrong.
joseph_23
Does the FX553 comes with a M.2 Sata III SSD or Sata III 2.5 Inch SSD? I was thinking of getting the Samsung 850 Evo SSD to upgrade it, but I am not sure if there is a free Sata III port.
ZrE0_Cha0s
well this really depends on manufactures warranty policy, even if u can upgrade your laptop, doesn't means that the manufactures can fix that defects parts of your own parts. basically some manufactures will tends to void the warranty due to user self mod their preconfig system.
so read up on their warranty policy 1st before doing any thing. or unless u know how to switch back those pre config parts.
Asus warranty policy : https://www.asus.com/in/support/Article/590/
ZrE0_Cha0s
i think both is there though, but need to check which model cos i found this one stated that there is one.
Storage
Hard Drives:
1TB 5400RPM SSH
1TB 7200RPM SSH
Solid State Drives:
128GB/256GB/512GB SATA3 SSD
Solid State Drives:
256GB/512GB PCIE Gen3X4 SSD
ref : https://www.asus.com/Notebooks/ASUS-FX553VD/specifications/
