POSB Everyday Card
sohguanh
Just want to ask for Geneco electricity end Jan 23 no more promo from posb everyday so reader will change to what card? Currently it is giving 5% but wait 60 days then get the rebate. Was thinking of using Amex
saintgtril
Hi all, anyone use this card for public transport i.e. SimplfyGo but the mrt/bus gates/devices cannot defect the card itself.
This problem only occurs recently. :(
reddevil0728
strange that you immediately suspect is widespread card problem with this card rather than your own card problem.
have you tried using this card in other context to test?
wenguang
if the problem persist, meaning ur card nfc function is defect, login to ibanking to replace a new one
jentang
My hb's live fresh also had this prob a few years ago. Called both dbs and transitlink but none can detect any prob and DBS refused to change, saying that there was no issue with the card until the transitlink told us to call DBS again and tell them it's definitely the card's problem then they replaced.
silverbomb
just say paywave constantly cannot tap at many shops, they will change instantly as damaged card. don't need go thru transitlink back forth.
wenguang
yes, recent i replaced my card due to nfc faulty. replacement request in ibanking is simple, just click damage card and request.
Belford
I have a question regarding Daily$.
I spent $290 on foodpanda last month but earned 13.89 only on dining. Why I didn’t get full $15 rebate? Or some order’s doesn’t count? Where can I get detailed earned daily$ (Paylah shows total only)?
Trazora
need to meet $800 min monthly spend
Belford
I do meet $800 on eligible spend and received $13.89 cashback on dining. My question is why I didn’t receive full $15 as I spent more than enough? Foodpanda cashback is 10% and capped at $15
saintgtril
Thanks all. I requested for a new card via online banking, received it less than a week. Using the new card now for SimplyGo. :D
Darwinson
Just saw the updated page for POSB Everyday Card. Simply Go 5% rebate revised till end of December 2022.
How to check this 5% rebate. Is it added to daily$ ?
so simply go say (ref no)/$15.75. Then the same is charged under my posb everyday card. Where to see the rebate is given ? Sorry for stupid question
