[Printer] Laser Printer questions lip lai !!!
invin
looking for a all in one laser printer. With wirelss connection.
Under 300. Any suggestions?
ImDrew
Hi all, is there any recommendation on good laser printers that are on promotion now? I am looking for one to print out my school notes. Thanks. :)
bladeice
My Fuji Xerox m255z paper jam open back cannot even see paper can see from front but cannot reach, any solutions? Or must send for repair?
Cleristo
1. Colour
2. Print Scan Copy (3in1)
3. Not sure about printing capacity, more or less meant for use from home during university study.
4. ~$200
5. Not really particular about extra features, but I suppose wireless connectivity could be helpful.
jus
Bro, may i know which is the cheapest mono laser in the market now? need it urgently.
thanks!
shengwei1
Hi All, need recommendations for on a printer for the below needs.
1. Colour - word documents (80%) pictures (20%)
2. Print, Print Scan Copy (3in1) - can still scan when ink/toner empty is a huge plus
3. low frequency (sometimes 1-2 months without print) but will print 50-100 sheets when I do.
4. As low as possible, however reliability that I can print when I need to is important
5. Duplex - must, able to connect to multiple PC via router/wireless etc is a plus
hi u can try getting Brother printer MFC-9330CDW laser printer as u are a low frequency user , and if u get an inkjet printer it will probably dry up after 1-2 months even leaving the printer on standby mode , unless u make an effort to print every once to month.
shengwei1
brother hl-1110 , going for $68 printing only, if u need multi-function without fax is dcp-1510 going for $148 both printers using the same toner , $52 for 1k pages
scenic98
I hear Fuji Xerox CM205fw will be replaced by CM215fw very soon. any idea what is the difference?
calbay
My Xerox printer, can't print after it's out of toner for one color(Which i don't use)
Are there any other printers without this restriction?
I actually print color only once in a while
unwanted
I'm looking for a network printer to replace my current Xerox, need color, any recommendation?
Nuvole
1. Colour
2. Print only
3. Low frequency (less than 100 pages a year)
4. Lan connection(wired)
Inkjet is hopeless for me. Everytime I tried to print I end up trying to clean the head... Currently using Samsung CLP315 with a print server, drum failing before the second set of cartridge finish... dun feel its worth to invest another drum.
Thanks in advance.
shengwei1
i understand your problem that u are facing, but usually the printers now requires u to have some toners inside before u can print, or probably u print on a default settings which its printing on using color , did u change to black and white printing whenever u print ??
shengwei1
1. Colour
2. Print only
Thanks in advance.
u can try using brother HL-3150CDN its a network ready printer going for $348 but if u get in show it will be cheaper and probably have free delivery without discounts at 348
tonerseller
Which model did you buy? Cause Xerox latest colour series can support mono printing provided you dont throw the empty color toner away.
tonerseller
You can look at Fuji xerox CP205 (No duplex printing but best colour quality among all brands) R.P $259 only with free $30 ntuc vouchers + powerbank
Or Brother HL-3150CDN (duplex printing but poor color quality) RP $349 only with $50 vouchers
imho you have to decided colour or duplex more important if you got more budget, you can consider this.
Fuji Xerox CP305d (duplex printing and decent colour quality. Colour quality lose CP205 but win brother HL-3150CDN) RP $449 only with $100 ntuc vouchers + wireless router to make it wifi ready.
tonerseller
1. Colour
2. Print only
Thanks in advance.
Go for Fuji Xerox CP205 $259 + $30 ntuc vouchers and powerbank
I think is very good buy cause usual price is $399.
Only brand the cover drum under warranty their 4 years warranty.
1st 2 years parts and labor free, next 2 years parts free only $60 for labour charge.
all 4 years on-site + drum under warranty
Toner
Black 2k $95
Cyan 1.4k $95
Magenta 1.4k $95
Yellow 1.4k $95
