[Printer] Laser Printer questions lip lai !!!
noobzpro
need wireless?
Duplex printers will be bigger leh you got space restrictions?
so let me do a more readable summary for you:
your requirements
print copy scan (duplex optional)
no budget
dunno if need wireless?
oh yes thank for reminding! wireless yes must! of coz i wan desktop size haha...
tonerseller
Fuji Xerox CM205fw lor..
No duplex thou cause i doubt you will happy with the size of the printer.
$520 + $50 ntuc vouchers + powerbank + if you are challenger member + 1 free black toner.
Print Copy Scan Fax + Wifi (ignore fax cause it is bundled in free for you it is ok if you dont use it)
The Big Bang Theory
Any recommendation for the following:
Manual Duplex
Scan
Mono Laser (Or ink if it's more cost-effective than laser)
Under $150?
Kiroshu
Manual Duplex
Scan
Under $150?
It depends on the number of pages you print. If your volume of printing and copying is not heavy you can try buying ink jet printer. But ink cartridge drys up very fast.
I would recommend laser printer. Its much more cost saving.
My brands of printer are more on Lexmark. If you keen on comparing the price and specs. Feel free to PM me.
noobzpro
Im curious why u guys dont recommend the newer 305? And what is the difference between the cm and the cp? Size really no problem i got a lot of space next to the router.
tonerseller
Oh cause I thought you have space restriction. You can go for CM305df as well. Btw CM305df is not a newer model. It is just another series with duplex printing.
Price $649 + $100 ntuc vouchers
toner
Black $112 3k page yield
Cyan $165 3k page yield
Magenta $165 3k page yield
yellow $165 3k page yield
warranty 3 years on-site
seebo
B&W much cheaper
Brother MFC-7860dw $348
or
Fuji Xerox M255z $359 usual price $399
Both models have what you want.
Colour with duplex cheapest is
Brother MFC-9330cdw $598 but colour quality is poor
or
Fuji Xerox CM305df $649
Hi sorry, forgot to include scanning of documents. Can you review recommendations?
- scanning of documents
- Color or B&W depending on price difference
- Preferably auto duplex
- Wifi
- Fax
- Printing speed not an issue so long as it does not jam
dynastysaint
Hi, my current inkjet printer dries out too fast so i am looking for a cheap mono black/white laser printer whereby i can save cost in the long run!
Hope the experts here can help recommend..thanks in advance!
1. Mono or Colour - Mono
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1) - Just Printing will do.
3. Printing capacity per month - For school purposes only so probably 300 pages a month?
4. Budget - 200+
5. Other extra requirement like wireless, iphone printing etc. - nope
fhkyhnpm
Anyone here using compatible toner for xerox m205b?
Now I am choosing in between original and compatible toner, and what is price for each? Any side effect if I opt for compatible toner on m205b.
shengwei1
tonerseller
4. Budget - 200+
Cheap Cheap Fuji Xerox P205b can already!
$99 + $30 ntuc vouchers
toner
standard yield $55 1k pages
high yield $95 2.2k pages
Warranty 2 + 2 years carry-in
Drum under warranty
Kiroshu
Lexmark X264 or X364 Mono. Print.scan.copy.fax.duplex printing. 33ppm for A4.
Return program print cartridge 3.5k--$180
High yield return program print cartridge--$348
4. Budget - 200+
Chowing_Hippo
hi guys if you do own a company and would like to upgrade your printing solutions to multi function printing devices with the help of IRAS's Productivity & Innovation Credit scheme(60% + $15,000 claim), feel free to PM me on any enquieries!
*toners, maintenance & spare parts included*
tonerseller
WA LAU SMLJ ! GO ESLEWHERE SELL YOUR STUPID COPIER OR PRINTER LA!
HWZER asking for print only you quote print.scan.copy.fax ? Dont come in here is anyhow advise people please :mad::mad::mad:
Seriously this printer thread become people coming in to anyhow sell ****
tonerseller
Lai Lai! M205b compatible toner is one of our popular range!
