[Printer] Laser Printer questions lip lai !!!
tonerseller
Just bought the Fuji Xerox CM215b and need some help on some questions,
1. Does the CM215b come with half-full toners?
Yes
2. Whats the expected yield rate printing full page A4 photos? Since the standard toners says average 1,400 pages based on 5% page coverage?
hard to gauge maybe a few hundred?
3. Any brand of reliable compatible toners for this printer to recommend and cost?
printcasa!:s13:
Thanks in advance :)
fifoent
i'm using the compatible toner for the first time. can anyone teach my how to install it as the size seems to be different from the original one and my printer can't detect it. I'm using the compatible TN2280 for my DCP7060D
Citiguy
I am now looking for a laser printer. Requirements are as follows:
1. Colour printer.
2. Multi function - copier and scanner.
3. Wireless capability.
Since the IT Show is around the corner, I intend to get on then.
Can suggest some good models that satisfy the above criteria?
Thank you all in advance.
abnnat
Looking for
1. monochrome
2. print/copy/scan
3. printing documents
4. budget <200$
5. bang-for-buck toner replacement
Pls recommend. If there's a wifi-version available (even if >200$) also would like to know the model and price.
Thanks!
Lecundra
Looking for
1. monochrome
2. print/copy/scan
4. budget <200$
Thanks!
I have the same criteria except I also need auto duplex, mac compatibility and also wireless capability. Budget is about $300. Appreciate the recommendation!
tonerseller
I am now lookibg for a laser printer. Requirements are as follows:
1. Colour printer.
Need duplex printing?
tonerseller
Looking for
1. monochrome
2. print/copy/scan
4. budget <200$
Thanks!
Non wifi
Fuji Xerox M215b $169+$30 ntuc vouchers
Toner
Standard yield 1k pages $55
High Yield 2.2k $95
Warranty 2+2 years
Wifi
Canon MF4720w $199
Toner
Standard yield 1.5k pages $105
Warranty 2 years
tonerseller
Brother MFC-7860dw $348
Toner
Standard yield 1.2k pages $54
high yield 2.6k pages $92
Drum
Standard yield 10k pages $98
Warranty 3 + 2 years
xtramadness
Looking for
1. monochrome
2. print/copy/scan
4. budget <200$
Thanks!
Dell b1165 I think. :)
$199, wifi also included.
Toner is. About $84 or so, 1.5k yield.
Got free delivery to house. Plus if got old printer, trade in for additional $100 off
Opachu
hi guys, i need to get a printer for home usage, like printing school stuffs, not hardcore printing.
1. Colour
2. Print, Print Scan Copy (3in1)
3. 100-200 / month
4. As low as possible
5. Duplex
6. Wifi
7. Has a printing app for me to print from my hp as sometimes I scan documents from my hp.
not too sure which would be ideal, i have been looking around, came across afew models:
1. HP ENVY 4500e-all-in-one Printer
2. HP Deskjet All-In-One Wireless Printer
would appreciate any recommendations :s12::s12:
tonerseller
Dell printers suck leh you dont need to find toners and is OEM from Samsung. Must as well pay abit more to buy Samsung SCX-3405FW
Exact model
tonerseller
1. Colour
3. 100-200 / month
5. Duplex
6. Wifi
Either one would be fine.
Both models are similar in terms of functionality just that 1 is 2 ink (blakc+tri colour combo)
Another model, 3520, is via 4 individual colour cartridge.
But then it doesnt matter since it is going to dry up also :s13:
Opachu
:s13::s13: alright thanks bro!
Shihtzu
any recco for
- print + copy + scan
- monchrome
- compatibility toner
- wifi or no wifi also can
looking at Canon imageCLASS MF4720w , is it good?
