[Printer] Laser Printer questions lip lai !!!
TrueB1ue
Where you all usually go to buy printer. All department store seem like they are selling at rrp.
dynastysaint
If you need duplex, you can go for Brother HL-2240d
$138
Toner
Standard yield 1.2k $54
High yield 2.6k $95
Drum 12k page yield $98
Thanks bro for the feedback. If i had to choose between Fuji Xerox DocuPrint P255 dw and Brother HL-2240d in terms of cost saving over time what will be your recommendation? :)
tonerseller
Hmm, P255dw ba.
P255dw CPP is 3.6cents
HL-2240d CPP is 3.5cents without drum
4.3cents with drum
tonerseller
looking for a mono laser 3 in 1
budget is less than 150
Brother MFC-1510 $168 or $148 (Cant remember)
Toner $52 1k pages
Drum $32 10k pages
Fuji Xerox M215b $169
Toner
Standard yield $55 1k pages
High yield $95 2.2k pages
Drum under warranty
whatsup1
Hi guys, I am looking for 2 printers. One of the printer requires to scan and print. The other printer I am looking for requires printing, scanning, fax, photocopying and supports wireless printing.
My total budget for both printers is $600. Hope to get advices and recommendations. Thanks
diverman0
Fuji Xerox CP205. $259 their usual price is $399.
Now promo + $50 ntuc vouchers + 1 black toner + wireless router
toners
Black $95 2k pages
c.m.y each also $95 each and 1.4k pages each
Is this offer still available ?. Thanks.
tonerseller
A few questions needed.
mono or colour?
scan and print printer with usb connection would be fine?
2nd printer need duplex printing / scanning?
As your budget is very tight so you have to think carefully regarding this 3 qns :)
diverman0
Thanks for the advice.
I had a Samsung CLP-310N. It ran out of colour for red, yellow and blue. It refused to print black and white even when the Black toner is not empty.
How to check whether it spoil or just replenish the coloured toners.
Should I give a try to get compatible toner or get original.
Thanks again.
whatsup1
mono or colour?
Thanks for the reply.
Both of the printers requires mono and colour printing.
For the scan and print printer, USB connection would be fine.
For the 2nd printer, wireless printing is required but duplex printing is not required
Hope that these answer would help :)
Firestone
after using Fuji Xerox CM305DF, i have to admit, the printer is quite retarded.
Scanning a document to be printed, the document will yield a black / white document even though selection is to colour... not sure which selection is wrong.
scanning the document will yield uneven printing tone... lighter @ right hand side of the page
wonder is this a defect...?
tonerseller
Thanks again.
I would suggest that you go for compatible as this model is no longer under warranty. You could get it from me ;)
The printer is build in such a way that black wont print when the other colours ran out. It is not defect.
tonerseller
In this case, I would recommend Fuji Xerox CM215fw @ $549 and Fuji Xerox CM215b @$399
CM215fw is the option for your second printer
CM215b is the option for your 1st printer
There are no cheaper alternatives already.. total $549 + $399 = $948
tonerseller
Do you mean that no matter how u change the photocopy color function , it stills photocopy in mono ?
whatsup1
Thanks for the recommendations. How about Brother?
ZenTape
Hi guys, I'd like to get a recommendation for a laser printer that's able to scan, print, fax, copy..
Budget max is $300. Appreciate any help.
tonerseller
Just a check, can i assume that you are talking about mono multifunction as ur budget is too low for colour.
cloverpark
My 4 year old canon LBP5050 original colors cartridges keeps smudging the paper even though they are depleted. Even the auto cleaning feature can't fix it after 10 attempts. Used a cloth to wipe the smudges on the cartridge drum but it doesn't appear to help much and must be repeated 2-3 times each time I need to print a new document. Also tried removing a color cartridge but it doesn't work.
Previously, I had been replacing only the black cartridge even though the colors are depleted - this is because a cartridge costs $100+ and it will cost a fortune to replace all of them. :eek:
I think the printer is lost. Can any kind soul please recommend a BW laser printer with low cost per page printed? Previously, I replaced the Black cartridge once very 9 months. :D
ps: I used Samsung previously, the printer was cheap, but the toner is very expensive.
