[Printer] Laser Printer questions lip lai !!!
geckoSG
I have skipped samsung totally. Drum expensive when I was on CLP-300, recently bought a CM215FW, still exploring the set after so much of recommendation here.
tonerseller
My 4 year old canon LBP5050 original colors cartridges keeps smudging the paper even though they are depleted. Even the auto cleaning feature can't fix it after 10 attempts. Used a cloth to wipe the smudges on the cartridge drum but it doesn't appear to help much and must be repeated 2-3 times each time I need to print a new document. Also tried removing a color cartridge but it doesn't work.
Previously, I had been replacing only the black cartridge even though the colors are depleted - this is because a cartridge costs $100+ and it will cost a fortune to replace all of them. :eek:
I think the printer is lost. Can any kind soul please recommend a BW laser printer with low cost per page printed? Previously, I replaced the Black cartridge once very 9 months. :D
ps: I used Samsung previously, the printer was cheap, but the toner is very expensive.
For the mono just print only model, you need wifi and duplex printing?
tonerseller
Yes mono - I had to dump my Canon because the color drums are worn out - too expensive to replaced 3 color drums. Duplex not required.
Cheapest consumable in the market for this category would be Fuji Xerox P215b already @ $99 with $30 ntuc vouchers
P215b
USB connection only
Toner
Standard yield 1k $55
High yield 2.2k $95
If you need wireless then it would be Samsung ML-2165w but original toner cost a bomb
Toner
Standard yield 1.5k pages $102
no high yield
cloverpark
P215b
USB connection only
Toner
High yield 2.2k $95
Toner
no high yield
Do you mean ML-215 fw?
bockscar
1. Mono or Colour
Can someone recommend:
1. Mono
2. Print only
3. Printing school notes. 100pages/month?
4. Budget under $200
5. No extra requirements.
balston_pig
can someone recommend me a printer.
1. monochrome
2. printing only
3. for notes printing ~100pages/month
4. budget below or around $130, but the cheaper the better
5. bonus if compatible toner is available. Need Auto Duplex printing!
Sensational
hi I am also looking for a recommendation for a laser printer. Its for home and school use.
1) printing notes. Colour if possible as well.
2) scanning
3) wireless (if possible)
Thanks in advance!
finclk82
can someone recommend me a printer with the following requirements?
1. monochrome
2. print, copy and scan needed (bonus if got fax function)
3. for general work printing - <100pages a month (mostly text based docs to be printed. Printing speed not an impt factor)
4. budget below $300
5. Need Auto Duplex printing and wireless direct printing (computer prints wirelessly to printer)
Reliability and low cost toner replacement is important for me.
Thx!
simymxh
Hello, can any bros help to advise:
I am using an ac router for wireless connection that sitting is in the living room.
The printer that I am planning to get will be placed in the living room as well.
However, my desk top is in a bed room, about 7m away from them.
Are there laser printers(colour for scondary school work use) that support ac wifi?
(Xerox or Canon is preferred)
Will the connection( signal ) via ac for printing wirelessly be any better as compared to connection via wifi a,b, or n?
Thank you.
mamborol
Looking for a mono laser printer for school notes printing.
Anyone can recommend? Budget as low as possible.
tonerseller
1. Mono or Colour
1. Mono
2. Print only
P215b
USB connection only
Toner
High yield 2.2k $95
Toner
no high yield
tonerseller
1. monochrome
2. printing only
Brother HL-2240d @$138. Got compatible toner
but no wifi only usb connection. Can buy compatible toner from me
tonerseller
1. monochrome
Thx!
Wa bo leh closest is Fuji Xerox M255z
@ $359 + $80 ntuc vouchers if offset then is below $300.
auto duplex printing
wifi to computer
print/copy/scan/fax
drum under warrannty + toner got compatible ones
tonerseller
Thank you.
Xerox printers only B/G no N no AC
No sure about Canon
caterham7
looking for a colour laser all-in-one; duplex preferred
found 1 model via online search, brother mfc-9140; hoping to see if there are alternatives to consider, thanks
Override2Zion
Just bought the Fuji Xerox CM215b and need some help on some questions,
1. Does the CM215b come with half-full toners?
2. Whats the expected yield rate printing full page A4 photos? Since the standard toners says average 1,400 pages based on 5% page coverage?
3. Any brand of reliable compatible toners for this printer to recommend and cost?
Thanks in advance :)
xtramadness
Just bought a dell b1060w laser printer at $20 direct from dell.
Came with 1 x 700 page yield toner + 3 x 1500 page yield toner. Free delivery too!
