[Printer] Laser Printer questions lip lai !!!
Peterlim88
hi :) just suggesting, u wanna try youtube see how other people do it then try diy? u can search for video demos of similar model type, watch afew vids to see how different people do it.. and then u try.. BUT u must remember what u did or did not do so that in the end u know how to put back all the parts :p
Hi, you just need to replace the pick up roller. $30 only on site repair.
Contact 82829494 Keith lau. he will help u.
Printer Toner Cartridge Recycling Service & Huge Savings Program | Printers' Toner Cartridge Recycle in SingaporePrinters' Toner Cartridge Recycle in Singapore
tonerseller
Hello, Can I get a few recommendations for a printer for small office? The specs I'll need are:
1. Color
2. Print Scan Copy Fax Wireless (All 5 functions must have)
3. 150 - 200 sheets/per month
4. Up to $800 max. Cheaper will be good, current printer I'm using is Brother MFC-440CW.
5. Very important for toner ink to last, lowest cost per page print. Good to have duplex function, smartphone printings etc but not compulsory.
I also saw some ads on the Epson L series ink tank printer, is it good?
Thanks in advance.
Dont buy ink tank for office usage. The downtime is costly for you and the warranty is crap. Your ink +tube not under warranty so each time jam = go service centre + pay $70 bucks. No point.
You can consider Brother MFC-9330cdw since you have been using brother or Fuji xerox CM305df.
Brother MFc-9330cdw $598 + $50 vouchers
Fuji Xerox CM305df $649 + $100 ntuc vouchers
Brother dont have good print out quality but have airprint
Fuji Xerox has good print out quality but their mobile app only can support jpeg/pdf printing.
tonerseller
Hi,
Would need advice for a printer.
Key thing needed would be auto save incoming fax to network drive.
Any recommendations?
Oh If dont need color just go straight for Brother MFC-7860dw. $348. dunno if can save to network drive but i know can save to computer folder.
tonerseller
Going to setup a mini home office, need a WIRELESS printer for:
1. Color
2. Print Scan Copy (good scan resolution)
3. Minimum print (< 100 sheets) per month
4. Budget < $500
Looking for lowest cost per page print. Good to have duplex function, smartphone printings etc but not compulsory.
More inclined to xerox printer.
Please recommend.
your budget no more other brands options le. Just go for Fuji Xerox CM215fw
$499 + $80 ntuc vouchers
No duplex and smartphone printing only supports JPEG.
Toner
Black 2k pages $95
Cyan magenta yellow each 1.4k pages each $95 also
Warranty 2+2 years on-site
drum under warranty as well.
Best buy and editor choice from hardwarezone as well
tonerseller
Hi everyone, I need a laser printer for our small-med size office.
We are using CM205 fw but we the cost of toner is expensive. We need to spend $80 for 1 toner every 3-5 months.
We need another laser or ink printer so is there a printer that could be better than the Fuji Xerox CM205 and the spec we need to be improve will be.
1.) Colour
2.) Toner would like to be cheap or maybe the toner can last for 10-12 months?
3.) The print speed shall be more faster than our current one.
(Fuji Xeros CM 205fw print speed 12ppm and first print out is 22sec.)
4.) Does not require scanner or fax since CM205 already did the job. Just a Colour printer.
Refillable ink printer shall be consider if the cost of the ink shall help to bring down our print ink or toner expenses.
Thank you.
Faster in the market is CP305d from Fuji Xerox $449 + $100 ntuc voucher
23 ppm colour/mono
Toner
Black 3k page yield $112
Cyan magenta yellow each 3k page yield each $165
Warranty 3 years on-site
for entry level no toner can last 10-12 months in the market so I would recommend you to use compatible to keep your running cost low.
tonerseller
Hi You may get its at a better price.
I have help u checked. Its $170. for
full set. Uses original cartridge with top
grade american toner. Free delivery.
If quality no gd it 100% Refund.
Sms or call him . +6582829494
wa lau spammer peter spotted
starch1990
hi guys.
Is there such thing as compatible Drum?
My CM305DF drum is damaged and needs replacing :(
IntelFlash
Recommend me a laser printer b/w will do
Must have wireless network printing featue and very very small!
TIA
slashboi
TIA
If you need print only. u can go for Samsung newest NFC model which is M2020W. It is one of the most compact printer u can find on the market with Wireless networking.I assume you need print only function.
tonerseller
TIA
Go for Fuji Xerox P255dw! Courts go expo show this weekend go beo beo. think got a lot of special deals.
Print only + wirless + got duplex printing.
Samsung u can skip cause toners are very expensive. Even for compatibles one.
spyder79
buy compatible toner from taobao. im using CP105. always buy 1 set of 4 ard S$45 including shipping to sg
PsyClick
i need replacement toner for P255dw. where can i source for cheaper options?
feel free to pm me TIA
whatsup1
Hi guys. I am looking for a 3 in 1 printer. Any recommendations? Thanks
Specs for the 3 in 1 printer:
1. Colour printing
2. Supports both wire and wireless
3. Duplex printing
4. Reliable and saves ink
ammeltz
Looking for monochrome laser printer with print,scan,copy features, wifi is a bonus.
I actually rounded up a selection but still undecided which one to go for, additional inputs are also welcomed!
Fuji Xerox DocuPrint M215b
HP LaserJet Pro M1132
Samsung Scx-3405w
Brother DCP-1510
hope you guys can help me out!
tonerseller
Cost per page 4.3 cents
Toner $95 2.2k pages
cost per page 5.75 cents
Toner $92 1.6k
Samsung Scx-3405w
cost per page 6.8 cents
Toner $102 1.5k
Brother DCP-1510
Cost per page 5.2 cents
Toner $52 1k
Hopefully this will be helpful and is a easy decision for you
tonerseller
1. Colour printing
3. Duplex printing
laser printer with duplex printing you need at least $600 u ok?
