[Printer] Laser Printer questions lip lai !!!
sgtiarella
Hi. Does anyone know of any laser printer repair shop in Sim Lim or North area? My HP laser printer 1102w doesnt feed the paper in most of the time. I cleaned the rubber feed but cannot put it back in. Need some help.
hi :) just suggesting, u wanna try youtube see how other people do it then try diy? u can search for video demos of similar model type, watch afew vids to see how different people do it.. and then u try.. BUT u must remember what u did or did not do so that in the end u know how to put back all the parts :p
eurofunk
need to get a printer/copier/scanner/fax (hopefully got fax function la) really soon like asap...
- need to print color sometimes but rarely, mostly b&w invoices.
- used for small work purposes so printing gonna be a lot so wanna keep low cost per page which was looking at hp 8600 but that one like so old model sia...
can recommend me something else to suit the above?
last but not least wheres the best place to get it (assuming u'll recommend Fuji Xerox) and if the such laser printers come with a free set of toners like ink jet printers?
tommyjen
Can you pls recommend a colour laser printer for my usage
1. Colour (mostly printing text and photo reports)
2. Print Scan Copy (3in1)
3. Probably 50 pages a month
4. Extras like wireless printing optional, Duplex not a must. Definitely need a autofeeder for scanning/copying purposes
5. Must be low cost for printing.
Most importantly, I need a FAST SCANNING, I mean FAST!
Do you recommend Fuji over Brother?
Thank you.
BrotherHong
Oh just go for Fuji Xerox CM305df $599 + $100 ntuc voucher and is 3 years on-site warranty
Hi All,
I am looking to purchase Fuji Xerox CM305df. The retail price from Fuji Xerox and Challenger is $649, no NTUC vouchers. 2 years on-site + 2 years carry-in warranty.
Any recommendation where can I get this printer at a better/best price? I don't really mind 2+2 or 3 yrs on-site warranty. Fine with both.
Thanks in advance!
v1hypersg
few questions :
i am using the printer for occasional printing, so laser is better as toner does not dry up in 6 months or less,
can anyone advise with occasional printing, how long can a laser toner last before harden ?
next the fuji xerox, model M355DF and CM305DF,
other than 1 is mono and other is color laser,
mono laser can have duplex print, copy, scan while color laser only duplex print,
if print or copy black for CM305DF, does the color toner gets depleted ?
it seems like the black will be created by mixing the color toners instead of using the black toner directly,
if i take out the color toner of CM305DF, will the printer show error and not print ?
i think i can live without duplex scanning but i would like to print color sometimes,
for price range, can i get a brother with same function ?
is there similiar model but with smaller foot print ? eg smaller size ?
shock
My fuji xerox c1110 change black toner only, with the colour toner depleted, can see horizontal dark line spacing 10 cm apart. So charging black toner only on colour laser is not woking. You need to change all toners and that will be 400 plus for black and colour toner for me. I am getting mono laser now. Not getting colour laser now. Drum on fuji xerox is 10k life span. I think other manufacture like canon not only need to change toner. Any expect on this?
bryanzzz
How do you guys usually buy your toners. I thought of buying toner powder off ebay but realise that the chip on the toner has to be reset as well. So mafan and a original toner for my printer (Samsung ML-2165) easily costs 70-80 bucks.
myoclonic
Hello, Can I get a few recommendations for a laser printer? The specs I'll need are
1. Mono
3. 500 - 1000 sheets/per month
4. Less than 800? Bang for buck?
5. Wireless+duplex. Inexpensive toner.
Thanks in advance.
xArchaic
Cloudi
is this model good ??? Not using any color printing.
Brother All-In-One Printer Model: DCP-7060D
essilor86
Hello, Can I get a few recommendations for a printer for small office? The specs I'll need are:
1. Color
2. Print Scan Copy Fax Wireless (All 5 functions must have)
3. 150 - 200 sheets/per month
4. Up to $800 max. Cheaper will be good, current printer I'm using is Brother MFC-440CW.
5. Very important for toner ink to last, lowest cost per page print. Good to have duplex function, smartphone printings etc but not compulsory.
I also saw some ads on the Epson L series ink tank printer, is it good?
Thanks in advance.
kalpbo
Hi,
Would need advice for a printer.
Key thing needed would be auto save incoming fax to network drive.
Any recommendations?
temptemp
Going to setup a mini home office, need a WIRELESS printer for:
1. Color
2. Print Scan Copy (good scan resolution)
3. Minimum print (< 100 sheets) per month
4. Budget < $500
Looking for lowest cost per page print. Good to have duplex function, smartphone printings etc but not compulsory.
More inclined to xerox printer.
Please recommend.
DuStyBoi84
Hi everyone, I need a laser printer for our small-med size office.
We are using CM205 fw but we the cost of toner is expensive. We need to spend $80 for 1 toner every 3-5 months.
We need another laser or ink printer so is there a printer that could be better than the Fuji Xerox CM205 and the spec we need to be improve will be.
1.) Colour
2.) Toner would like to be cheap or maybe the toner can last for 10-12 months?
3.) The print speed shall be more faster than our current one.
(Fuji Xeros CM 205fw print speed 12ppm and first print out is 22sec.)
4.) Does not require scanner or fax since CM205 already did the job. Just a Colour printer.
Refillable ink printer shall be consider if the cost of the ink shall help to bring down our print ink or toner expenses.
Thank you.
Peterlim88
Hi, just to share i was attended by this person before. You may like to consult this person, Keith lau. He is from company- "001 Supplies"
He is helpful. He will advise you accordingly. He carry huge range of products for office printing needs with very gd price. Need not buy from him. HP 8282 9494. Email- askme@001supplies.com
Peterlim88
Peterlim88
1. Color
Thanks in advance.
