[Printer] Laser Printer questions lip lai !!!
tonerseller
I don't like Fuji cos of the page counter which just stops printing once you hit 1000 pages. A lot of wasted toner if you don't refill the toners yourself.
Mai refill la the health hazard bo hua one.... Toner particles if inhale will have a lot of problem to ur body
Mine 100% newly manufactured so dont need to save a few $ and harm your precious body
tonerseller
Oh. Heh. What would you guys recommend?
Let me fill out this,
1. Mono or Colour
Color preferably. Will be printing color documents.
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
Multifunction(excluding fax) would be nice, but not an important factor
3. Printing capacity per month
I guess about a few hundreds pages/month
4. Budget
5. Other extra requirement like wireless, iphone printing etc.
iPhone printing would be nice.
I have a question, I noticed that there's "memory" on laser printers. What is this for? And what's the ideal memory to have? And what are the things I should be wary of from using compatible/refill toners? Like for inkjets, I read, third party inks may damage the printhead etc. And inkjets are susceptible to clogging when ink dries out.
Budget? $500 ok?
Laser printer uses toner powder so it wont dry and there is not printhead. They uses drum to attract the powder and align the powder onto the paper.
For compatible/refill toners look out
1. got warranty bo
2. testimonials from others
3. prompt response time
4. salesperson knowledgeable about printers or they just sell the toners
- This will ensure that the seller have sufficient knowledge and experience to handle the issue if your printer get screwed up by the toners
tonerseller
hi, is samsung C460W a good buy? just get one few days ago, and now my lady boss wanna get another.... wish to know is safe to use compatible/refill toners? the color no different with original? can damage the printhead?... thanks. :o
If your printing volume not high still ok else jialat cause once you print until the waste toner full, you have to change already.
For colour alternative is
Fuji Xerox CM215fw
or
Canon MF8280cw
tonerseller
Hi,
i am looking at a printer for me and my sister (Both of us are Uni Students)
we need the following functions:
1) Auto print both side (is it call auto Duplex)
2) Both colour and non colour (mostly non colour)
3) Easy to set up
4) Should be quite heavy usage becuz nowadays SIM need print own lecture notes
5) Easy to Purchase :X
if possible can name me 2 to 3 models so that i can consider.
Prefer maybe less than 300 ba
Thanks in advance
Cheers :)
Need Scanning/Copying also?
If just Print only (take note, only black and white printing only cause your budget too low. But should be sufficient for uni usage)
Top of the list
1. Fuji Xerox DocuPrint P255dw
Retail Promo Price $159
Freebies: $30 Ntuc vouchers + 1 standard cap toner worth $105
Toners
Standard (2.5k pages) $105
High (5k pages) $180
Drum under 2+2 years carryin warranty
1st 2 years parts and labour free
3rd and 4th year parts free but will have $30 labour charge
2. Brother HL-L2365dw
Retail Promo Price $168
Freebies: $10 Shopping voucher + 1 ream of A4 paper
Toners
Standard (1.2k pages) $56
High (2.6k pages) $92
Drum 10k pages $98
Warranty 3 + 2 years carry in
1st 3 years parts and labour covered
4th and 5th year parts only labour no fix pricing
storm913
Hello, looking for new printer cos my inkjet spoiling soon, can't feed the paper well.
requirements:
1. Color printer
2. Print Scan Copy Fax (4in1)
Multifunction
3. Printing capacity per month - roughly 80 per month only
4. Budget - the lower the better, but durability is what I'm looking for
5. Other extra requirement like wireless would be nice
KwayChup
Need recommendation.
- Mono ( I don't think colour can fit into my budget)
- As cheap as possible
- Printing school work only
- Any upcoming promotion?
Fuji Xerox P215B Vs P115W Vs P225B
ceecookie
Can I check with you if the fuji xerox m115w use the same toner cartridge as the m205b?
parcomo
Hi,
Any recommendation for laser printer?
1. Mono or Colour
3. Printing capacity per month Low
4. Budget Not more den $190
5. Other extra requirement like wireless, iphone printing etc. None
Secondly, any opinion/reviews on Canon MF4720W?
Thank you.
tonerseller
P215b $89 +$20 ntuc vouchers
-Single side printing only
-USB connection only
Toner Standard cap $55 1k page yield
High cap $95 2.2k page yield
drum under 4 years carry in
P115w $79
-wifi connection
Toner $42 1k page yield
drum $49 10k page yield
warranty 1 year carry in
P225d $129
-double side printing
-usb + network connection
Toner $49 1.2k page yield
high cap $85 2.6k page yield
drum under 3 years carry in warranty
From what i see, i believe P225d will be better buy and duplex printing will suit your needs
tonerseller
Hi,
1. Mono or Colour
Thank you.
Based on your requirement, Canon wont be suitable as their strength is in color like MF8580cdw. For mono, their toners a slightly on a higher pricing
of $105 of 2.1k page yield. (5 cents for per page)
In constrast, Fuji Xerox M115w toner is 1k page yield $42 (4 cents per page)
and selling only @ $149 at Challenger.
Cheap Cheap!
tonerseller
requirements:
1. Color printer
Multifunction
Cheapest is Fuji Xerox CM215fw $499 now got $80 NTUC vouchers + 1 free blck toner. (promo until 15 March)
With your volume shld be printer spoil u also haven change toner.
Black Toner 2k page yield $95
Cyan toner 1.4k page yield $95
Magenta toner 1.4k page yield $95
yellow toner 1.4k page yield $95
Warranty 4 years onsite inclusvie of drum *
*1st 2 years parts and labour free, 3rd and 4th year parts free but have labour charge of $60 bucks
If you need doubleside printing then can recommendation Brother MFC-9330cdw @ $598 with free $80 shopping vouchers
but take note that brother need to change drum.
parcomo
Cheap Cheap!
Thank you for the recommendation.
So Fuji Xerox's toners can print 1000 pages max?
Shutterfly
Please help to recommend based on the below
1. Mono
2. Print Scan Copy (3in1) - Scan/Copy is good to have
3. Printing capacity per month: 200
4. Budget: $250
5. Wireless
I have shortlisted these two but not sure about their quality.
Brother DCP-1610W vs Fuji Xerox M215FW
Kindly advise. Thanks in advance! :)
taugeh
What is the printer equivalent to Fuji Xerox CM215FW?? Maybe a cheaper alternative if there is???
tonerseller
1. Mono
4. Budget: $250
5. Wireless
Brother DCP-1610w $168
Toner
1k page yield $52
10k drum $49
warranty 3 + 2 years carry in
1st 3 years all cover except drum
4th and 5th year parts covered but need labour + drum charges
Fuji Xerox M215fw $239
Toner
1k page yield $55
2.2k page yield $95
warranty 2 + 2 years onsite inclusive of drum
1st 2 years parts and labour cover
3rd and 4th years parts cover but have $60 nett labour charge
or if cheap cheap this model also can
Fuji Xerox M115w $149
toner
1k page yield $42
10k drum $49
warranty 1 year carry in except drum
best option is M215fw but end of the day M115w is a steal cause of the cheap pricing. To be honest you can not losing out much cause of brother carry in warranty. Unless you live near beach road, else chances are you will buy need printer once they spoil so end up you wont be utilizing the warranty.
In this case might as well get something with on-site warranty (M215fw) or a model with cheapest toner (M115w)
Shutterfly
Toner
1k page yield $52
10k drum $49
Toner
1k page yield $55
2.2k page yield $95
toner
1k page yield $42
10k drum $49
Thanks for the detailed input. Do you think I will be able to get better offer next week at IT show? Or price usually will not change much?
