[Printer] Laser Printer questions lip lai !!!
elusia
thinking of getting a laser printer after years of using an inkjet and constantly having to change printers cos inkjets spoils easily if you don't print often. Before deciding, need to ask a few questions on laser printers.
Can they print on smooth materials like transparent films, photo or sticker paper? Occasionally need to do some craft work. Will an inkjet work better here?
If i occasionally need to print photos, will a laser printer work well or better to get a separate inkjet / photo printer?
kandinsky
There are some commercially available materials that are designed for printing with laser. Suggest you head to a stationery store like Popular and check it out. If it supports laser printing, it will be stated on the package. E.g., You can't use inkjet photo paper / stickers / film in a laser printer, you have to use what was designed for laser printing specifically.
I've never tried laser photo paper, so no idea how the quality is. Personally that's what I do. B/W laser for text/documents, inkjet for photos.
elusia
I see. Thanks for advice! Will check it out then!
by the way, is the Fuji Xerox CM215fw very bulky? that's the recommended laser printer with option to print colour right?
kandinsky
Most welcome. I only have personal experience with b/w laser.
I'll leave to the colour laser experts to comment on the CM215fw.
edwinsng
1. Colour
2. Print Scan Copy (3in1), auto-duplex
3. Printing capacity per month = 200
4. Budget = $700
5. Wireless
Which laser AIO printer to get? Fuji Xerox or Brother?
Litmuss
Can recommend which AIOs for the following requirements?
1. Auto-duplex
2. Print, Scan, Copy
3. Wireless
4. > 95% of the time mono printing, < 5% color printing.
5. Preferably less bulky than my current Fuji Xeroz M205FW
6. Budget - below $250
atalyer
Informative thread :D
1. Mono
2. Print Scan Copy, [Fax good to have]
3. Printing capacity per year : <100 [Not trolling, just need a standby AIO for home office]
4. Budget : <$250
5. Duplex [Good to have], Wireless [Good to have, but not important]
Would you recommend Canon printers? I'm leaning towards Canon only because their printers are in black... Hate the yellowing on white printers after a year or so :s13:
Was looking at the Canon MF221d
sadako00
Hi, I'm looking for a printer for the following usage. Please help to recommend:
1. Colour
3. Printing usage is low
4. Able to print on glossy flashcard material (300gsm)
5. Auto duplex is good to have.
Thanks
tonerseller
Thanks for the detailed input. Do you think I will be able to get better offer next week at IT show? Or price usually will not change much?
Brother promo dont change at all but as for Fuji Xerox, we will be expecting something different like more freebies and price drop.
tonerseller
For photos, inkjet/photo printer
For laser printer, they do work on transparent films / sticker paper but get those meant for laser printer else your printer wil spoil
tonerseller
yup for color printer it is the most option. Btw saw new model from Fuji Xerox , CM225fw. Dunno issit replacement for CM215fw. Hopefully they will display at this show.
tonerseller
1. Colour
4. Budget = $700
5. Wireless
Fuji Xerox will be CM305df $649
Pros good print out quality
cons external wifi (not inbuilt)
Brother will be MFC-9330cdw $548
Pros cheap
cons poor print out quality
tonerseller
1. Auto-duplex
3. Wireless
Can forgo color bo? if you cannot forgo color your budget not enuff.
secondly you may want to consider inkjet instead cause all laser printers are big in size.
tonerseller
1. Mono
4. Budget : <$250
In this case you only have HP canon or Brother to look at.
Canon MF 221d is fine as well as Brother DCP-L2540
tonerseller
1. Colour
Thanks
Copier nia lol
Thickest in the retail printers is HP and is 216sm only
Litmuss
If forgo color, which laser printer you recommend?
If go for inkjet, any recommendation?
garth6
looking to get a printer for home use during the show.. or maybe elsewhere..
1. Mono
2. Print or Print Scan Copy (3in1)
3. probably < 200 pages per year
4. 200
5. wireless, duplex printing
maisatomai
1. Mono or Colour
Mono
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
4 in 1
50-100 pages per month
4. Budget
$250-400. As low as possible
5. Other extra requirement like wireless, iphone printing etc.
Wireless
