[Printer] Laser Printer questions lip lai !!!
knightskid
If you guys using Fuji right then there are three things that you need:
1) Used Original Toner (not the one that comes free)
2) Toner reset chips - I paid about $10 for 4 but its much cheaper if you buy more at one time.
3)Toner powder.
Refilling is quite easy. Just follow this video: https://www.youtube.com/watch?v=iLoxvO-HTOs
I have not bought original toner before, the printer i bought only free half-filled toner, and from then on, i bought the oem toner, then once finished, will just buy chip and powder to refill.
Icetray
OEM one also can. That's what I'm using. I just heard that you can't use the free one but I've honestly never tried to see if it'll work on the free one.
yuukaze
Looking to buy laser printer with the following requirements:
1. Mono
2. Print only
3. 1000 pages a month?
4. $300
5. Must have wireless capability, small footprint preferred. Must be able to print on A5 paper. Preferably cheap consumables also : p
Was looking at Brother and Fuji Xerox, but for Brother we must also change the drum is it?
Thanks in advance!!
tonerseller
Hi, I'm looking for laser printer with the following requirement. Any recommendation? Thank you
1) color (but normally use B/W)
2) print, copy, scan, fax (4in1)
3) about 300pc per month
4) can use varies size paper. eg B5
5) reliable for home office use
6) auto duplex
7) other feature optional
Brother MFC-9330cdw or Fuji Xerox CM305df also can.
Actually if can I would rather you use just black and white laser printer if color is not necessary. Cause it is really cheaper for mono laser printer.
tonerseller
looking for a printer that can do DADF
mainly to convert paper to PDF.
so just need print , scan copy.
if you doing digitization, you should buy scanner from Fujitsu. Dont buy mfp cause their feeder not meant for heavy duty scanning. Their roller will wear out fast.
tonerseller
hi is there a shop/person who can top up the toner cartridge if i buy my own toner powder? Maybe need one time just to teach/guide me for the very 1st time hehe
dont do refill. Buy compatible straight. Last time I also sell refill toners. But the health hazard is really not worth the money saved/earned. Thus, I changed to sell compatible toners and quality the same also after doing internal testing. My side here cheap cheap.
tonerseller
1. Mono
2. Print only
4. $300
Thanks in advance!!
Brother HL-L2365dw $168
need to change drum
Fuji Xerox P255dw $159
dont need to change drum
both also have compatible toners
Alphas
Lasers/ Sled has a better value when you get oem cartridges. In long run, the cost is lower and better print quality.
AphoticFX
Hi guys. I have been an inkjet user for years and years, my inkjet printer is starting to fall apart. I thought this might be an opportunity to jump over to laser printing. Is there anything I should about laser printing before purchasing one? I read a couple of replies, and it seems Fuji Xerox is the brand to go to. Where do you guys purchase your OEM/Compatible toners?
Icetray
I don't like Fuji cos of the page counter which just stops printing once you hit 1000 pages. A lot of wasted toner if you don't refill the toners yourself.
AphoticFX
Oh. Heh. What would you guys recommend?
Let me fill out this,
1. Mono or Colour
Color preferably. Will be printing color documents.
2. Print, Print Scan Copy (3in1) or Print Scan Copy Fax (4in1)
Multifunction(excluding fax) would be nice, but not an important factor
3. Printing capacity per month
I guess about a few hundreds pages/month
4. Budget
5. Other extra requirement like wireless, iphone printing etc.
iPhone printing would be nice.
I have a question, I noticed that there's "memory" on laser printers. What is this for? And what's the ideal memory to have? And what are the things I should be wary of from using compatible/refill toners? Like for inkjets, I read, third party inks may damage the printhead etc. And inkjets are susceptible to clogging when ink dries out.
something
hi, is samsung C460W a good buy? just get one few days ago, and now my lady boss wanna get another.... wish to know is safe to use compatible/refill toners? the color no different with original? can damage the printhead?... thanks. :o
FreeRoon
need recommendation
Hi,
i am looking at a printer for me and my sister (Both of us are Uni Students)
we need the following functions:
1) Auto print both side (is it call auto Duplex)
2) Both colour and non colour (mostly non colour)
3) Easy to set up
4) Should be quite heavy usage becuz nowadays SIM need print own lecture notes
5) Easy to Purchase :X
if possible can name me 2 to 3 models so that i can consider.
Prefer maybe less than 300 ba
Thanks in advance
Cheers :)
tonerseller
From me!!! Proven usable with lots of testimonial
:s12::s12:
