zippy79
- Aug 10, 2000
4 colour toner for colour laser printer replacement only $128?
no lah, is each color $128
.4 colour toner for colour laser printer replacement only $128?
Colour Fujixerox laser or Hp Laser better in term of toner cost?
Any recommend for laser printer can print and scan duplex on adf for A4 with wireless?
Any laser printer can do duplex scan?
It will be colour. Any recommend?Colour or mono?
There are quite a few models that can do it. But for colour, they tend to be quite pricey. I have the HP m477 that does single pass duplex scan.
I think HP281fdw is quite good... i was previously using Fuji Xerox...It will be colour. Any recommend?
Laser printer using the size is bigger...Hello all,
I'm looking to buy a colour laser printer to replace my faulty inkjet printer. This is my first time buying a laser printer so i have no idea which brand is the most cost effective and would appreciate any kind recommendations from here.
I'm looking for the following features
1) Colour Laser
2) Print, Scan, Copy. (Fax is optional)
3) Wired or wireless connection are both ok.
4) Longer warranty (on-site) is preferred.
5) For home use so smaller size is preferred
6) Low usage per month, around 50 pages per month
7) Budget - Prefer to be $800 or below if possible
Thanks in advance!
can try HP281fdw...
https://store.hp.com/us/en/pdp/hp-color-laserjet-pro-mfp-m281fdw
Hi all, bumping up this thread. Wondering if this hp model laser printer still holds true?
Looking for a budget colour laser printer for home use as well. Don't need any fancy bells and whistles but need something reliable and cost efficient.
TIA!
Hello all,
1) Colour Laser
Thanks in advance!
Hello all,
1) Colour Laser
Thanks in advance!
Lazada have, but seems like not selling mono laser, only colourAnyone know where can buy fuji xerox printer?
