Did some shifting today. Shifted my HDD cage to the left. But it is blocking all of my sleeved cables... Need to figure out where else can i put my hdd and ssd, or bo bian must put at 5.25" bay le and get 2x sata power extension cables.
I fitted my Monsta at the front. There is a clearance of 150mm to play with. The fans are at the front so it isnt included. As i am going for p/p for front, total thickness within the case should be 85+25=110mm..
Also, there are 2 areas in which you can mount 120mm fans. First is flushed right to the top and second is somewhere in the middle. However, for the first option, the rad cannot fit in at all. So the second option is used.
Rad touching the 5.25" bay
Screws on first option not aligned to the rad's mounting holes.
Thus, the second mounting positions for 120mm are used.
Also, as the rad is at the 2nd option, the clearance from bottom port to base of 750d is around 24mm. Not enough for 90 degrees adaptor.
