Project ~Poseidon~
shadow84
Small addition to my rig... Ducky Shine 3 TKL DK9087. A big thanks to royfrosty for helping me to get it while i was away. Coming next would be an alu-red God-Of-Death (Bleach) keycap to remove the ESC key.
Simply love TKL layout...
Brightness at its minimum... But, i simply love reactive mode..
shadow84
O rings came in on Mon and i installed them into my gpu bridge...
At the same time, i changed the position of the cpu block's tubing...
Tried running the system, found a small leak at the sealing bracket. It seems underneath it, there are also gasket slots. Requested for AQC to sell me some. But, at least the main part of the gpu bridge isnt leaking anymore... Same goes for other fittings.
shadow84
Bought the Plantronics Gamecom 780 7.1 headset from Amazon at S$82.00. Since i cant contact local distro and they never reply my email, felt no such need to support them bah, even if i can get it locally at $105.
shadow84
Finally, no more leaks !!! Now hope that my components are still working...
sglords
enermax cluster adv stastic gd or not?
dunno wan go ppcs helix or taobao cluster adv
shadow84
Im having some issues for it... It gets loud when i set to 12v. Not sure if it is caused by the design of my case or the fan itself.
When i ran it against AP-15 outside of my case unmounted, it moves more air than AP-15 but is slightly louder.
Locally alrdy selling Helix 120, why need go to ppc to get them?
sglords
I saw in best bargain before... But u can klkk around to find the lowest price... Do update if you had gotten it..
Thanks. Manage to wipe last 2 pcs from best bargain and 1 from pctheme at v gd price :D
pc theme left 1pcs.
sglords
From wad I read on ocn temp few degree away from GT and quieter but wear put faster mount vertically.
So jus give it a try since was lookin for white stastic fan which only enemax cluster, corsair sp120 led and helix for me to choose
shadow84
My benchmarks... Did i do the settings correctly? Temps were 54 degC max, Core clocks were 1125 mhz, +31mV.
icydrake
Hi, was thinking of building a similar build to yours, can share roughly how much you spend on the rig itself? Thanks. :)
shadow84
That is hard to calculate since i overhauled once... but my WC costs $1500 +/-.. Exact figure unknown yet.
If you are talking abt PC parts, you can just download a pricelist and compare my parts to it.
