Glad I found this thread.
Can someone tell me if this diamond is a good buy? It is from bluenile.
$12,393
GIA Report Check
GIA Report Number: 2135777040
Report Type: GIA Diamond Grading Report
Date of Issue: August 26, 2011
Round Brilliant
Measurements: 6.54 - 6.56 x 4.04 mm
Carat Weight: 1.08 carat
Color Grade: F
Clarity Grade: VS2
Cut Grade: Excellent
Proportions
Depth: 61.7%
Table: 57%
Crown Angle: 35.5°
Crown Height: 15.5%
Pavilion Angle: 40.6°
Pavilion Depth: 42.5%
Star Length: 50%
Lower Half: 80%
Girdle: Medium to Slightly Thick, Faceted (4.0%)
Culet: Small
Finish
Polish: Excellent
Symmetry: Excellent
Fluorescence: None
bought an Ideal Super Cut 1.56ct G VS1 from Amy at JannPaul..
first visit there.. but totally sold when i compare the quality and price against a same size lazare.. hope i got it right?
Hi,
i am very new to Diamond and was quoted the following for 2 diamonds.
Super Ideal Cut
0.78 F VVS2
$9500
Solasfera
0.78 D VS2
$9400
Seems like it's really quite a jump from the quotes that i see from other forumers.
Does VVS2 really command such a high price, is Solasfera worth the extras, are the price a bit high for a 0.78, which stone is more worth it and should i consider other stones?
Hi,
Super Ideal Cut
0.78 F VVS2
$9500
Solasfera
0.78 D VS2
$9400
.x7 .x8 .x9 are prime cuts, being a prime cut adds up additional value.
hate to spoil the market, but i think super ideal cut for $9400 is really expensive. Chop chop chop.
bluenile.com/sg/diamond-search?track=head#diamonds_pid=LD02479305
I believe after you have visited JP, you should be well educated and have adequate knowledge to source your own Super Ideal.
I would advise not to limit yourself to just one jeweller, give yourself more options by visiting more jewellers to compare the quality and price.
the 0.78 carat Solasfera seems like a better buy.
D color is great
Clarity need not go to VVS2..VS2 will appear same as VVS2.. so VS2 is great also
I will go for solasfera any time..
in this case with same price, solasfera look like a better buy.
i am wondering whether the spark of the solasfera worth the additional money spend? or should i get a bigger diamond instead with the same spec.
i thought a .9 is a prime cut cos it is nearer to 1.
.7 and .8 also consider prime cut?
What is consider a prime cut then?
Any others to recommend?
So glad i found this thread
i barely just started Part 1 of this thread but can give me a headstart and recommend some retail or private jeweler???
My budget is 10K...
if going for Tiffany....how much should i set aside???
TIA![]()
Ooo how much was it?
I got a 1.59 Solasfera F VS1 for my wife too.
On the day.. 12th December 2012. With 12 Honda Cars, we set to surprise my dear Jolyn Hsieh at her workplace. Proposal 12pm 12min 12s, which makes everything to be....... 12.12.12, 12cars 12.12.12 and ofcoz not forgetting 12 red ROSES
https://www.facebook.com/media/set/?set=a.10152339249070384.947969.711035383&type=1
