Proposal Ring - Part 2
Milo-Dino
oh...u were thinking of a 0.6+ at what color and clarity??
maybe u can ask for a lower color? G color and VS2? maybe can hit ur price for the 0.7.
or ask for 0.67~0.68??it would be closer to what ur gf wants. Guess its once a lifetime yeah
I already deposit for a G 0.63 VVS2. They didn't have any bigger 0.6x ones
NoviaL
wah ok.. so you went with your bf....
I went with another guy friend who should be getting married soon also. Getting the ring is to be a "surprise" for my gf although she has been hinting and saying she wants 0.7 :(
Yap..I went with my guy..he's a practical man...he say he will be more willing to buy something which I like than he like..as I'm the one who will be wearing...ur gf say want 0.7 but did she try it on her fingers? Because I myself have a 0.26cts ring so I told my guy as long as bigger than that can already..although I wish for at least a 0.5 la..but now that I got a 0.46, I'm ok with it..because I know I will have a better colour n cut..I know if can compromise to G colour and cut to VS2..I may get the 0.5..but anyway, the money is spend more on the colour and cut..cuz mine is 0.46 colour E and cut VS1..and Hca 1.3..so yup..
Milo-Dino
ya she did... she tried the tian po hearts on fire series 0.71ct.... with a whooping price of $17k :(
I thought it looked abit too big... but she of course thinks it's ok...
but ok la.. she willing to take 0.6... colour wise, we couldn't tell the difference between F and G at other jewellery shops like goldheart etc
NoviaL
Oh...so u talked to her? Well..don't worry..I believe If u're comparing the massive production jewellers...I think jp's will not disappoint ur gf ba..because in the end, it's the bling bling effect that attracts...haha..congrats! !
Ms_Spellbound
Just visit JP..and I would really say..they are really super frank and willing to share their experiences...so in the end, I'm sticking to my initial purchase...he explained that it was cloud and I also wore my super clear "zeiss" lens glasses to see clearly..n since since its a lot small small spots then ok..if 1 or 3 spots very pan dang..haha..anyway, he also told me it's rare to have a 0.46 in the shop..so far he only saw 4 throughout his 3 yrs in jp..so I guess I'm very lucky as I avoided the jump to 0.5...am a happy girl now..haha..n also requested him for a ring tracker :)
What is a ring tracker and how do i get it?
Crazy85
Need help on the diamond below, which is a better buy if
0.52 f vs 1 $200 more than 0.54 g vs 1
0.54 g vs 1
ImageShack Album - 4 images
ROUND BRILLIANT
Measurements 5.23 - 5.26 x 3.21 mm
Carat Weight 0.54 carat
Color Grade G
Clarity Grade VS1
Cut Grade Excellent
Depth 61.2 %
Table 56 %
Crown Angle 34.0°
Crown Height 15.0%
Pavilion Angle 40.8°
Pavilion Depth 43.0%
Star Length 50%
Lower Half 80%
Girdle Medium, Faceted, 3.5%
Culet None
Polish Excellent
Symmetry Excellent
Fluorescence None
Clarity Characteristics Cloud
VS
0.52 f vs 1
ROUND BRILLIANT
Measurements 5.16 - 5.17 x 3.18 mm
Carat Weight 0.52 carat
Color Grade F
Clarity Grade VS1
Cut Grade Excellent
Depth 61.6 %
Table 57 %
Crown Angle 34.5°
Crown Height 15.0%
Star Length 50%
Lower Half 80%
Girdle Medium to Slightly Thick, Faceted, 4.0%
Culet None
Polish Excellent
Symmetry Excellent
Fluorescence None
Clarity Characteristics Crystal, Knot, Feather
hollander
0.54 g vs 1
ROUND BRILLIANT
Color Grade G
Clarity Grade VS1
Cut Grade Excellent
Depth 61.2 %
Table 56 %
Crown Angle 34.0°
Crown Height 15.0%
Star Length 50%
Lower Half 80%
Culet None
Polish Excellent
Symmetry Excellent
Fluorescence None
VS
0.52 f vs 1
ROUND BRILLIANT
Color Grade F
Clarity Grade VS1
Cut Grade Excellent
Depth 61.6 %
Table 57 %
Crown Angle 34.5°
Crown Height 15.0%
Star Length 50%
Lower Half 80%
Culet None
Polish Excellent
Symmetry Excellent
Fluorescence None
Size wise .54 would be much better, you can really tell the difference if you are going to compare it to .50. Between the two,.02 is really a small difference.
H&A of .52 looks better than .54 ;-)
Color Wise F to G are both good choice, Clarity VS1 is nice as well.
200SGD goes to the .02 jump on the size and G to F jump on the color.
Go for the .54 diamond, and keep your 200sgd in preparation if you want the settings with meeles ;-) (ordinary setting starts 500, with meeles starts 900)
Both are really good diamonds, I should say.
topek88
Thanks to this forum/thread, i visited JP and bought my ring from them.. paid a deposit in january but finally collected the ring ytd.. What do u think of the diamond?
NoviaL
SUPER good...what's the damage? Mind sharing?
Milo-Dino
This is the one I placed a deposit for...
HCA
ASET scope... does it look abit imbalanced? or is it more of the angle that the scope took the photo?
Ideal scope
This H&A looks alright though...
comments?
NoviaL
The diamond is $2700, setting $1200.. How about urs? Our spec is around the same right? This is my 3D drawing..
Mine is smaller by 0.01..haha.. carat size 0.46 then same E colour, but mine is a higher grading of cut,VS1..damage for loose diamond is $2.9k, my setting is very simple kind so is $550..looks like u got a very good deal...mine like $200 more than yours..n mine got spots..but I do like my own diamond's proportions :)
Grizz.P
HCA
Ideal scope
comments?
The diamond looks slightly tilted to the sideway in the Aset scope.. Can see it from the bezel light leakages part...
epiphany01
hi guys... am still scouting around with intention to go to JP as my last stop. but just for my own budgeting purposes first, may I know how much would a Solasfera cost for the following parameters? just a rough gauge would do
1 - 1.2 carat range
VS2 - VVS2
G-E range
thank you!
benfire7
wellll~~~
0.62
Triple excellent
VS2
F Colour
4.9k without setting:s12:
Well, for people who want spotless diamond... I have found a reason to convince, console or wahtsoever wanna it call...
I have 2 spots on H&A anyway...so
2 spots equal (me and her) only....
after etch and setting, wont be able to see anyway...
For 1 spot - only one love
hopefully yours have no 3 spots...
For 4 spots - You, Her, and 2 children...
many spots> glazing stars just like her:s22::s13:
