EricMagnusLensherr
- Dec 17, 2004
There is another difference between GIA and AGSL.
AGSL uses technology and light returns to grade their diamond, but GIA uses stone to stone comparison to decide on the diamond cut grade.
The significance of this is that while some GIA triple ex may not shine that well as their proportions are not as good, they are generally bright when viewed from most angles due the method used by GIA (using humans eyes as the criteria) while the method used by AGSL (as well as people who uses ASET and Idealscope) will lead to very beautiful and vibrant stones from commonly viewed angles, one of which is the diamond in its face up position.
I knew their different grading methodologies but didn't consider this. Thanks for bringing it up
I agree with you that a 0.8 is around 6mm while 1 carat is around 6.5mm with some minor differences due to diamond depth.
However, please note that you do not have a vernier calipers now. All you have is your eyes. Imagine the center a diamond is very bright and the sides are rather bright too, compared with another diamond whose center is less bright but the sides are dull. This difference in lighting effect will cause you to have a misconception in size. In a super exaggerated analogy (warning, this is the most extreme case which is not likely in real life), how much bigger is it when you try to estimate the size of a lighted bulb compared to it when it is off.
If you google on the web you should be able to find a JP video which shows how a 0.9 super ideal is same size as a 1 carat GIA common triple ex.
Very valid analogy, and i did consider this factor as well, i just didn't think this optical illusion can make up for the size difference when placed side by side, and i still don't. From what i've seen, among this kind of optical tricks which can help in making a diamond look bigger, even factoring in a setting, such as NSEW/Compass prongs etc and the "glow"of the super ideal, in a side by side, I can still tell a 0.8 from a 1ct. But only more extreme ones like a halo can make it look significantly bigger or big enough for a 0.8 to seem like a 1.0 in a side to side comparison, and that also depends on the halo style etc to trick/distract/confuse your mind. If not placed side by side, then yes, i agree with you, the "glow" effect and normal settings tricks is probably enough to trick a viewer in to thinking it is bigger then it is, and close to a 1.0ct.
Hope I am making sense here
