Proposal Ring - Part 2
[GorgeouS]
yup they just did... sharing here with all the bros and those who needs help with diamond selection.
should be of good help to all
not just to buy diamond based on cert. aset scope is very important.
I remember them showing me a Triple Excellent diamond against their Super Ideal diamond.. It's even more obvious in person. It really shows you can't just buy a diamond based on the certificate alone.
LeslieHJL
Is it really not worth getting one from Tiff & Co?
How much should I be expecting to pay for a very simple solitaire?
final1
You need to be more specific with your question or else dont think anyone can answer your question
ltchew
hi guys..
im getting my wedding bands soon n im considering JP since most of u guys r recommending them..but are they famous for their diamond selection only?? because im probably nt going to put a big diamond on the rings..maybe just a very small one or dont put any diamond at all..in this case do you guys still recommend i get from JP??
Glitzger
hi guys..
JP also does customisation of wedding bands so what you can do is show them designs of bands you prefer, your budget and get them to customise for you.. That is what me and my SO are doing... And I can have the best of both worlds: mini solasferas in my wedding bands and a brellia for engagement ring..! But you will have to give them more time since they are really busy.. I'm doing mine a good 6 to 8 months in advance.. Very kiasu... =p
ltchew
yea i already have my own design..but was thinking if they were recommended due to their nice selection of diamonds..then probably its not really a big factor in my case..
they need 6-8months?thats really long~~~~ i probably need it by mid/end of may >_<
jhchoo85
It depends what you want them to do with JP
For my case, I love the Brellia.. I had a custom design that I drew for them, and this was the procedure:
1.) Discussed the pro's and con's of the design.
2.) Suggestions of way to improve the design.
3.) They created a 3d image of 95%+ accuracy to the real thing, this was fantastic as you know how your ring can look like exactly with what kind of diamond.
4.) After deciding, next step is crafting and confirmation of the wax model.
5.) Crafting of the real ring.
6.) Final ring was excellent and way pass my expectations :D
Timeframe is anywhere from 1 month to 2 months depending on what design. Their crafting is not done locally like the retailers do here.. so it can take slightly longer... but it was definitely worth the wait :)
Carnage
My design took more than 2 months from the date I chose my diamond.
2 months is a very good guess. Also depends on how busy are they.
ltchew
but like i said earlier..when talking about JP, most people talk bout their diamonds, but for my wedding bands i might not even put any diamond on it, thats why i was thinking shd choose them or not..
Carnage
You have to give them the customised designs yourself. That was what Jann told me.
jhchoo85
They are known for their quality in their diamonds and also their craftsmanship in customization..
It will depend on what you want to do...
The price of their bands are defintiely cheaper than branded..
Craftsmanship quality is good..
IMO, what's most important is that you get to have a 3d imaging of your design for customisation (especially if your planning to customize)
ltchew
thanks guys..
yea i already have my design..probably would schedule a meeting with them tomorrow n see how it goes..
anyone did platinum rings with them b4?? he quoted me 2.5k-3k for 3mm and 3k-4k for 4mm..i mention i might need a diamond at the center of the ring..not sure what diamond he use to quote me tho…..shall find out tomorrow..
Doreamon 0507
Proposal Ring
Recently i brought a diamond ring from SK Celistar
Shape and cut : Round Brilliant
Carat Weight : D1 - 0.48
Colour Grade : Near Colourless
Clarity Grade : VS-SI
Price : S$1500
After brought i feel a bit worry because it is in house certification report not from GIA ! What should i do ? can i return ?
BoulevardLim
Bro.. Can't see clearly.. they are all thumbnail size.. and post larger pic??
Opps sorry hahahah :s13:
Here you go!
Love the pink diamond, gives it a very subtle look :s12:
[GorgeouS]
Here you go!
Your ring drawing looks quite plain and simple (no offense)...
But in the 3d pictures... it's a whole different story...
Looks simple but somehow very unique at the same time... Very nice!! Classy too :)
Carnage
thanks guys..
Wow, platinum and white gold so much difference?!
final1
Price : S$1500
You may submit it for certification by yourself if you are worried.
