Proposal Ring - Part 3
justbehappy
Look at both spec. almost the same.
Price difference of 2k.
Lol.
Quite sure the 4k scope will be chui.
6k from jp sounds about right I think. Super ideal? octagon?
Yup it’s super ideal haha. But not sure if it’s overpriced not, wanna hear from experts here lol
KinoChoco
JP prices are generally standardised and best in terms of quality.
But I personally will drop the color to F and clarity to VS2 to save some money, provided they have something in that range or u got the time to wait.
alamakazim
guys, any shop to intro for affordable bling bling?
0.5~0.6C
H
ideal
SI1~VS2
with setting ard $2.5k
KinoChoco
0.5~0.6C
H
ideal
SI1~VS2
Not possible bro. It can never be a real ideal at such price range. The setting itself cost 500-1000, you’re technically looking for a 0.5 diamond for 1.5-2k. You can definitely get a diamond at this budget, but I can guarantee you it won’t look good and comes with flourecense
H0cusP0cus
Would I be able to get a ideal cut 0.5 diamond with G, VS2 with setting be around 3-3.5k?
Planning to make my appointment with JP but don’t want to sound like an idiot with this request. At this budget would a 0.3X super ideal cut be better or a slightly bigger ideal cut?
KinoChoco
Might be able to get a genuine ideal at 3k+ for your stated specs, but setting will cost 600-1.2k depends whether u want side diamonds or not...I can’t remember the exact pricing, don’t worry, they are nice people that don’t get commission off individual sales, hence not pushy Nor will they judge you, u can feel at ease and let them educate you.
Edit: personal opinion, at this budget, I’ll opt for bigger ideal and not a 0.3x Super ideal.
alamakazim
cannot meh? why I see brochure and online search can get leh...
SG mark up so much ah
just a simple plain 4 crown setting btw
my SO say ... big enough ... a little shine can liao...
any shop can get such quality...
KinoChoco
Because those are not real ideal cut. Cheap diamonds are everywhere, quality wise, it’s a diff case, but just get whatever both of you are happy with.
lorsc0825
You can try asking, no harm about that. I was offered a 0.4x E VVS2 super ideal diamond for about 2.9k, which is doesn’t look that small comparing with a 0.5.
Also depends on what setting you want.
BlackCube
Yup it*********s super ideal haha. But not sure if it*********s overpriced not, wanna hear from experts here lol
Their price quite fixed one. So if they quote 6k, then more or less there ba.
It's with settings rights. Then sound about right ba.
BlackCube
Here alot of posion. Will look at spec and so on.
If u both ok with any, and don't care about the spec then go ahead and buy what u both like.
ilovetoeat
0.5~0.6C
H
ideal
SI1~VS2
Or maybe you can consider man-made diamonds like me :D, slightly cheaper or even alternatives! Can get your size, better stats and possibly cheaper than your budget!
throwawaygrad
I considered man-made (lab grown?) and moissanite too but I saw online reviews that the girls could still tell the moissanite doesn't sparkle like regular diamond + gets cloudy easily? But lab grown diamond (as in not substitute, the actual chemical composition is indeed diamond) is so far ok, haven't heard anything too bad about it.
alamakazim
no wonder ... u all jin ATAS
just got a 0.54ct $2.1k @ SK
VVS1
near colorless
maybe not so call ideal cut... but decent bling liao
mero_cwj
JP 0.81 G, VS1, $8600
Gd price ppl??
End up you also go JP ah :s13:
Usual price for JP. G VS1 quite good value for money also. But see whether the very very faint yellow tint is a stickler for you
Sent from Nokia 3310 using GAGT
ahboy82
Lookimg ard la, nt yet decided.
I know here is all siao JP one...
mero_cwj
go see the house of hung stuff also lor, recommended as usual by the people here
if more chin chai, can have a look at poh kim jewellery, at lower delta road there. no scopes one but prices generally quite good
