Real International speed tests
What ISP are you testing on?
  • Total voters
    64
miloaisdino
Umobile KL is very fast.
of course la.. u mobile is a temasek subsidiary (100% ownership) :)
firesong
Deluxe Member
Oh I know. I chose that for that reason, and that's why I was very surprised.
Just redid the test with the same strange results. What's with this abysmal routing? Home conditions are the same - dad watching Singtel TV, mom on Viu and sis on Netflix.
Thought occurred to me: you both on ONT right? I'm on the 8240T5 ONR on bridge. I assume we're all on AS9506, so that shouldn't be the problem.
And a sudden spike here.
I think my slow upload speed has something to do with the browser based testing. Somehow I am not able to test with the Win 10 app out of Singapore/Malaysia/Indonesia.
Mobile app has no problem to choose the server's. I have faster upload speed using my Huawei P20 than the Acer Swift 3 laptop (bought in Dec 2017, Win 10, Core i5 8250U, 8GB RAM, 256GB SSD).
Yes using ONT. And IP is 121.7.xx.xx.
miloaisdino
hmm.. could you try setting dscp from your desktop (set to 48). maybe it might help :D
firesong
Deluxe Member
You both are on the same IP block then. I'm on 121.6.x, Earlier I was on another block altogether (can't remember now.)
That would be artificial results though. I intended for this to be more real-world.
TanKianW
wow, the latencies are so low!! (except optus Melbourne). especially the china mobile. the latencies you are getting are comparable to from my azure server.. btw is yr myrepublic 1G normal plan with static ip or the gamer plan? thanks
I am using 1G MR with static IP. Non-Gamer.
MR DL speed is 1G, UL speed is 500M. Add in another 4 servers to cover the bases. Taken at 9pm today.
MR Singapore:
CBN Jakarta:
kdatacenter Seoul
Uni of Texas:
miloaisdino
i do think there's actually something wrong with the uni of texas server.. even speedtest from my azure server has poor results
Using the SpeedTest CLI tool to get rid of the effect of browser. The trick is to get the SpeedTest server ID. By default it only list the servers around your test locations. The solution I use it to use VPN to connect to other locations to get the list of servers around different locations.
SpeedTest server list.
https://c.speedtest.net/speedtest-servers-static.php
08 Nov 2020, Singtel 1Gbps plan, 8:10am to 8:25am.
ONT -- Singtel Mesh Router -- Win 10 laptop with UGreen USB 3 Ethernet adapter.
Interestingly upload is very fast but not download.
c:\work\speedtest>speedtest.exe
Speedtest by Ookla
Server: Singtel - Singapore (id = 13623)
ISP: Singtel Fiber
Latency: 2.03 ms (0.12 ms jitter)
Download: 946.72 Mbps (data used: 686.2 MB)
Upload: 904.19 Mbps (data used: 1.0 GB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/668f83a4-3378-49e3-9022-4e709217e103
c:\work\speedtest>speedtest.exe -s 16089
Speedtest by Ookla
Server: University of Texas, Austin - Austin, TX (id = 16089)
ISP: Singtel Fiber
Latency: 233.79 ms (0.25 ms jitter)
Download: 171.45 Mbps (data used: 207.8 MB)
Upload: 136.92 Mbps (data used: 120.2 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/8c70c7ab-253b-4096-84f2-85a362fc4fd4
c:\work\speedtest>speedtest.exe -s 30932
Speedtest by Ookla
Server: Optus - Melbourne (id = 30932)
ISP: Singtel Fiber
Latency: 110.93 ms (0.06 ms jitter)
Download: 37.24 Mbps (data used: 64.6 MB)
Upload: 896.07 Mbps (data used: 1.2 GB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/55724198-e5cd-41a5-a3f0-59ed9fa35b3d
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 109.59 ms (0.25 ms jitter)
Download: 38.03 Mbps (data used: 60.2 MB)
Upload: 229.77 Mbps (data used: 385.2 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/1b66bb19-7ed6-4d02-af0c-b994a00a9db5
c:\work\speedtest>speedtest.exe -s 1783
Speedtest by Ookla
Server: Comcast - San Francisco, CA (id = 1783)
ISP: Singtel Fiber
Latency: 186.23 ms (0.25 ms jitter)
Download: 3.72 Mbps (data used: 5.1 MB)
Upload: 442.95 Mbps (data used: 581.3 MB)
Packet Loss: Not available.
Result URL: https://www.speedtest.net/result/c/edabd3f1-c51f-4bad-85fe-9abbb2639097
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 187.71 ms (0.28 ms jitter)
Download: 5.01 Mbps (data used: 6.8 MB)
Upload: 352.50 Mbps (data used: 582.5 MB)
Result URL: https://www.speedtest.net/result/c/920cce49-7514-49cc-81a2-ea3abcb20371
c:\work\speedtest>speedtest.exe -s 24333
Speedtest by Ookla
Server: Rakuten Mobile , Inc - Tokyo (id = 24333)
ISP: Singtel Fiber
Latency: 80.18 ms (0.24 ms jitter)
Download: 13.72 Mbps (data used: 23.0 MB)
Upload: 737.74 Mbps (data used: 1.3 GB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c1041817-a05b-4e82-b6c3-946d265c3b4a
miloaisdino
Average around 150Mbps to 200Mbps even though there are some spikes at higher speed. Using Singtel 1Gbps plan here and Chrome browser, monitored using Windows 10 Task Manager.
Interestingly second time it is faster, above 200Mbps and up to 500Mbps.
from my experience, singtel google drive uploads and downloads are throttled to 400mbps (provided idm or download accelerator is used), while torrents can easily exceed 400mbps provided its well seeded
940am comcast sanfrancisco (over wifi)
if you need an idea of when its peak hours in sg:
yusoffb01
ok. not as bad as whizcomms, thottle most single connections to 10MBps. uploading 10GB files is a torture
firesong
Deluxe Member
Sunday Morning (approx 11am), on wifi
Power cycled my network. Surprisingly got assigned a new IP address, also in the 121.6.x block. Speeds are finally up to expected levels, but there remains questions needed to be asked about the discrepancy.
Singtel:
Thailand (AIS Fibre Bangkok)
Malaysia (U Mobile, Kuala Lumpur)
Australia (Optus, Melbourne)
USA (Comcast San Francisco)
Japan (Rakuten Tokyo)
Canada (Bell Mobility, Vancouver, BC)
Hong Kong (China Mobile)
Yes, just downloaded Free Download Manager and tried the same Google Drive download again, the speed hovers around 41MB/s to 52MB/s, so yes it is between 328Mbps to 416Mbps.
As for bit torrent, just tried Ubuntu 20.04 AMD ISO and I can only reach up to 40MB/s with the average speed of 25MB/s, not yet above 400Mbps.
Get better download speed now at around 12pm.
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 185.73 ms (0.12 ms jitter)
Download: 91.37 Mbps (data used: 114.4 MB)
Upload: 337.93 Mbps (data used: 565.7 MB)
Result URL: https://www.speedtest.net/result/c/64b31732-966a-49e8-9e78-e4ff09082712
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 236.08 ms (0.10 ms jitter)
Download: 98.06 Mbps (data used: 146.6 MB)
Upload: 153.72 Mbps (data used: 263.4 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/9475e23f-c983-4b5e-80c4-29ef03b99db8
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 108.99 ms (80.53 ms jitter)
Download: 553.12 Mbps (data used: 793.7 MB)
Upload: 363.93 Mbps (data used: 586.4 MB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/7d533f0f-2e69-4365-bce8-d67981dcf6a2
c:\work\speedtest>speedtest.exe -s 13623
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 2.53 ms (0.09 ms jitter)
Download: 946.95 Mbps (data used: 473.6 MB)
Upload: 905.36 Mbps (data used: 1.1 GB)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/4e7f9e30-4e8d-45f2-9061-7b9e09442915
miloaisdino
hmm could be due to torrent client.. i use qbittorrent and randomise port, forced encryption. qbittorrent has no connection limits (eg 2000) :) torrents are also more demanding and require ssd to reach top speed (as not written in order)..
I see.
I do not use bit torrent myself so this is just for testing purpose. I am using qBittorrent as well but with the default configuration. I will try later to change configuration to see if it can reach higher speed.
I usually use wireless so previously qBittorrent can saturate the wireless link.
