Recommendations for fridges
adrianloh
Have anyone used a 2 door left and right. The left is a freezer and the right is for veg etc. Is it good? Is Bosch KAN92V1350 good?
Poshua
LG Gold fridge any reviews on it? It’s kinda the tallest fridge so space ultilised.
WhatToBuy
Hitachi Fridge Circuit Board Spoilt
Hi, i just got a new hitachi fridge R-VG560P7MS. 5 months old only and it broke down. Seems like circuit board is spoilt.
Is it advisible to just replaced the circuit board? Will it last after that? I did not buy extended warranty
Bak_Chor_Mee
Hi guys, am looking at both Samsung RT35K553ASL and Panasonic NR-BX468XSS1.. which will u guys recommend? Anyone here using either of this?
Evolver
Isn't it under 1 year warranty?
ciscube1
My LG lasted for 20yrs.. and it's giving intermittent problems lately. Maybe it's time to get a new one.
Any recommendations?
I have been using my Samsung fridge for more than 10 years and it has never gave me any issues. I will buy another Samsung fridge when it is time to replace this.
Hugo
I've narrowed to Panasonic , LG and Samsung. the inverter names are confusing
Panasonic - smart inverter
LG - linear inverter
Samsung - digital inverter
any idea if these are very different technologies or are they just naming conventions for the same thing ? thanks
petetherock
Moderator
Moderator
Each company will have their own names for inverter tech.
Twin cooling systems aren't available for all fans, eg Samsung has separate fans for the freezer and fridge.
Door alarms to warn you about forgetting to close the doors are nice.
Note the depth, height etc, eg a deep fridge may be hard for people with short hands.
Look at the star rating, but note, if you keep opening and closing the fridge, you may be better off with two smaller units than one big one.
See how the shelves are arranged and see if that level of flexibility is enough for you.
allcc6
Anyone using LG door-in-door fridge? I'm looking at GS-M6262NS. Any reviews?
Duncallmebro
Not going to use samsung again
Spoiled less than a month after purchase RT32K503ASL ..replacement not working well (chiller not sufficiently cold) after 2 years
Third party repair guy checked and said sensor spoiled but hard to get replacement part unless contacting samsung centre:mad:
Iamafan
Thanks for sharing. I think now Samsung gas "established" the brand, seems like their appliances is starting to cui easier as they mass produce for the demanded crowd.
Jenchoo
For new fridge, what is the temperature I should set and how long to on it for before placing food in it?
Poshua
