Recommendations for fridges
harky
I looking for 2 door one for my mom, which use lesser electricity
Not too big size as i had a fridge base (any idea got ppl charge to remove the fridge base?)
fridge base which measure by 61cm X 61cm make me abit hard to find correct size fridge,
haha
chewingyu
LG Fridge
Any one using the LG GBB5191PZ fridge? Thinking of getting as it is about the only one so far that can fit in between my cupboard and wall.
Saw it on offer at IT Show.
Please give me feedback. Thanks.
petetherock
Moderator
Moderator
BlessChwee
Why not a Samsung or LG or Panasonic?
This Borsch is basically a regular fridge.. you can get the above three for less money.
It's like you want an Audi for the sake of getting an Audi?
That Borsch is made in Turkey.. FYI
Many negative feedbacks on Samsung and LG brand and thinking if sm European Brsnd will be better.
The inner capacity is also quite large compare to similar size fridge
chialee
Anyone tried Midea's fridge? In particular the MRM584S? Link at midea.com.sg/portfolio-item/mrm584s
firebear
Just to share with all,
family bought a Sharp fridge, within 1 year 3 months
electronic parts broke down (according to technician)
After sales service agent, customer service very bad attitude but technician is ok. expect weeks for parts to arrive.
Either we are unlucky or Sharp suck!!
no more Sharp for us.
sickid
I bought a Hitachi less than 1 year ago. So far so good. And i like their design compare to other brands.
Alphas
I am using it. Bottom freezer make it easy to take things out, top compartment has many shelves, and the shelves can be shortened. Has eco function and temp display.
Bonhun
Anyone got a Toshiba fridge and found it good? Thinking of getting a 2 door GR-AG46SDZ-ZW.
harky
worth to change refrigerator door rubber or buy new one?
nvm, i go tb buy the rubber :D
RyanJ
smeg
the only nit is the door seal vacuum is super strong.
otherwise pretty.
