Recommendations for fridges
tortoise18
Do you still have the noise issue for your fridge? The noise happens only when the temperature is minimal?
Yes.. and whenever i open the door wide..
The freezernis too strong.. i put at min and already has frosting.. compared to my previous fridge
Broadwalk
All my fridge just died on me last night, I need a fridge and need recommendation. :o Any one can introduce and recommend me one? :o I dun really keep many things. :o
cstanhwz
LG has a 4 tick fridge model now.
Think the more energy efficient models coming.
So I am holding my purchase for fridge for the time being.
Hopefully more models with 4 ticks will be released soon.
ichinisan
Actually 3 ticks is good enough. The annual savings are not much of a difference.
josh123
Looking at the absolute amount of electricity used is a better gauge of savings as fridge is turned on 24/7. Good to also right size the fridge unless aesthetics is important,which usually come in a bigger package
lcpteck
Anybody have experiences with Hitachi refrigerators before? Currently looking at those Bottom Freezer or French Bottom Freezers.
How about LG?
lcpteck
Anybody have experiences with the 330L models? Looking to save space due to small kitchen in a 4 room BTO flat. Or should I be looking at 400L models or higher? Don't have much width space to begin with hmm...
calkel20
no ideal, i bought another slightly smaller Hitachi model rb410p6msx, much cheaper (paid 680 only) than Panasonic with same bottom freezer design and 100l freezer capacity to store for my cheap frozen poultry volume order.
Posted from PCWX using dog walk volunteer needed, pm me
Hitachi [Hitachi]Hitachi R-BG415P6MSX 2-Door Bottom Freezer Refrigerator (330L)
Got the glass beige one in May for 700+
Good to be different from black or SS.
SylTSH
I'm considering this particular model too! Do you have a pic of your beige fridge? I haven't seen the actual beige product anywhere, they're always showcasing the black or gradient version :(
calkel20
Got your request, so i will snap tonight.
calkel20
MhjjNDT
Not sure why it fails to load.
