Recommendations for fridges
calkel20
I went down today the sales staff recommended LG and Mitsubishi instead. The LG is GB-B3449PZ while Mitsubishi is MR-CGX41EN. Kinda set my mind on Hitachi
R-BG415P6MSX but the sales staff raised a valid concern. The interior walls are rough unlike the usual glossy and smooth, which seems to be easily stained.
From a user like my wife, not an issue.
Only issue is the side panel for eggs and stuff, can easy dislodged by ME.
The bottom freezer is quite a huge capacity.
Depends on one usage as well.
MaoZeDuo
Thanks and good to hear. Fits my budget and required dimensions and nice colour options :)
calkel20
It is slender and tall.
So your height must be cleared.
We factored in the space required for side ventilation as well, so only this fit our requirement.
Samsung, barely can fit.
luckygal
I love this fridge, the colour and the interior as well.
MaoZeDuo
Hi, still waiting for response from parisilk. Those who got the hitachi r-bg415p6msx, any idea if there will be an issue if the socket is 10cm above the fridge?
Kitaro9202
Just checking those fridge that is able to disperse ice and water need pipe connected?
Ginnylim07
Sorry to ride on this thread. My freezer recently has ict forming in the freezer. Is there anything wrong with the freezer?
calkel20
No problem la. Wire should be long enough.
Last is to relocate the wall socket.
You can call them to speed it up if you are in a rush.
MaoZeDuo
My Samsung RS62K61A77P/SS lately "sweat" alot... Not sure if it's due to the weather or something wrong Liao...
petetherock
Moderator
Moderator
Is there any issue with the seals of your fridge such that cool air is escaping out?
wyx03_2002
hi, does anyone know where to source for a set of door seal/gasket for Hitachi R-D6800X fridge? Found water droplets/condensation around the door frame since 2~3 months ago. Most likely the seals/gaskets are failing. Quite a waste to replace this 5yo ~$4600 Japan made fridge just because of defective seals/gaskets. Hitachi SG quoted >$700 for seals/gaskets replacement, which I think is too much. Thx in advanced!
bjornng
hey guys,
gonna kick start my 4-room bto journey, very fresh and would like to seek your advice.
im looking for a fridge, budget pref <$1000, 2 door. saw this LG bottom freezer GB-B4059 but cost like $1.6k. would there be any suitable alternatives? as long as can last long, can le. also don't have to be bottom freezer, open to choices!
