Recommendations for fridges
mosmos
High Honorary Member
Wah.. mosmos dunno u also sexperts on fridge! Can recommend me a good one around 1k? :o
Sent from ..... using GAGT
I am bad luck with fridge so is washing machine, that time I bought Hitachi fridge also bought $999 Hitachi top load washing machine 13kg with inverter. I like that it uses less than 200w. But now think again I guess daily use once for only 60mins, 200w or 500w does not make much difference.
after using 2wks, during spin dry I heard like metal scratching sound. Called for repair, the repair man said the belt loose. I was wondering why inverter not direct motor still use belt and use 2 weeks already loose?
after Washing machine and fridge incident, I don't trust Hitachi liao.
SecretAgent
hahaha.. I am actually looking at that Hitachi rvg480 something at best Denki imm... looks like I better look at something else. Panasonic? Mitsubishis?
xiangzeng
I use LG direct drive inverter motor WFT1271DD, 12 kg load due to washing large items,top load washing machine. No belt on motor. Best buy so far, good washing cycles and cotton threads are visible instead of my previous samsung washer side door, all cotton threads are crumpled and squeezed together.
LG 4381PZ fridge - very good and saves power and powerful coolness.
LG 55SJ850T tv - very good resolution and impressive pictures.
LG is good in above products.
mosmos
:s22: my lg 42" tv use 3yrs can see rainbow lines across screen, never use the usb port or hdmi, never plug anything or unplug or use other fuctions other than watch free to air tv.
now using hisense 49" smart tv with dvtb2, bought at $400 going to reach a year old so see can it last, even if breakdown is ok, price cheap
xiangzeng
Maybe your LG tv set did not turn out as it should in quality. But so far so good for me. Bye. not intending to debate on this. Refer to LG service centre, labrador park circle line station, if has any queries.
ayuchan
I am looking Panasonic NR-CY558GW (French door design with Prime Fresh Freezing). Any review on this?
mosmos
For those looking at 380L fridge, qoo10 got sale until Sunday
wongminmin
thanks for the head-up.
EuropAce been doing offer....that time side by side fridge only $900+ but 1 tick.
this 1 look decent price...but like panasonic, 1 of my worries tho...the dtc easy spoil...
what is no frost?
mosmos
what is no frost?
Europace side by side qoo10 selling sgd690 now, offer until Sunday
Nowadays the ticks have been changed, many products even Mitsubishi fridge maybe 2 ticks only
wongminmin
my fridge used for 15 years..defrost timer spoiled once...
but now the plate crack...
the NEA tick is not accurate 1... i see the power consumption.
EuropAce ER 752Q (side by side) Annual Energy Cost $207
EuropAce ER 6401S Annual Energy Cost $121
People suggest avoid hitachi,LG,panasonic, currently my shortlist is europace and mitsubishi... dunnoe whether can gamble on europace :s22:
mosmos
Side by side very big freezer of course use more electricity.
But the savings $690 compared to other brands $1000k or maybe more, pay $400 difference enough to pay electricity for 4 years if other uses $1xx annually
pandazilla
Does anyone know how NEA or whoever calculate the fridge volume and energy efficiency?
Some salesman told me that method is disadvantage to fridge with variable speed fan. Another one I noticed is that the manufacturer (MIJ Hitachi) claims is more than the NEA label volume.
mosmos
this type just take it as an info, not as if the difference in electricity like in tens or hundred $$ per month
mosmos
Strange my current Hitachi is still going strong after 3 years.
My old place also use Hitachi, still in use after more than 9 years.
:s22: I guess cannot compare old one bcause no inverter and motherboard to control everything.
your 3rd year old on using inverter and digital control? then you are very lucky or i am suay
mosmos
I am looking to get Panasonic NR-CY558GW,two ticks. Is Panasonic brand for fridge ok?
fridge quite wide, do you have so much space?
i prefer fridge that are deep and tall, for my kitchen, i place next to kitchen cabinet, if too wide might block some cupboard door from openng fully.
