Red Wing shoe Thread
thegardens3b
Hi all, I just recently purchase a new Iron ranger seconds from US. Any tips on maintaining the shoe?
no need maintain. red wings are for thrashing.
if not use obernauf LP
different people have different preference. the above is just my opinion :s12:
kazuki666
Second that. Red Wing boots are work boots, too much "pampering" wasted.
Sent from Xiaomi REDMI NOTE 4 using GAGT
Shalomp
Dvoiddeckbench
Anyone know where can I get this? I tried finding at Orchard Gateway but couldn't find. I never try a Red Wing boots before. I am wearing US8 for Onitsuka, is it the same sizing for Red Wing as well?
Thank you
Sent from 我要擊敗蟲國人! using GAGT
thegardens3b
Thank you
usually i can go a size down . e.g US 7 for you for red wings.
but better to try it yourself before commiting
thegardens3b
Are all red wing sizes the same? If yes, then I will just try one then online order.
for me its more or less the same cos im not particular if it is too loose or not fitting exactly.
better for you to try the model itself but for me, so far all models i use the same size no problem.
hope it helps :)
generally go one size down wont be too off. if you afraid it will be too tight, go half a size down. try one pair and see for yourself
Dvoiddeckbench
hope it helps :)
Thank you so much! Can you take a pic of you in your wings?
dong2che
Wore my red wings til the sole need to change then stopped wearing a few years...now the leather stiff need to break in again LOL.
kingkong007
Fyi, Redwing OGW is having some sale on old new stocks. Saw Beckman, workboat round toe and chukkas. All from $300 to $350.
I am not allfiliated, just happen to saw it when I was there buying boot cream and foam cleaner.
alanjw55
Buddies wanna ask, where can I get my oxfords to be cleaned?
Lazy to do it myself lol
paladin
Feder sports.
Peninsula plaza or people’s park complex.
I am surprised you cannot find in Orchard gateway as there is a red wings store there and the shop besides the red wings store also sells red wings boots
Thank you
