Redmi Note 10 series
jazzz
Thinking of getting the note10 pro from taobao which has a better cpu compare to global set. Any advise?
Ctrl_Alt_Del
Global version of China note 10 pro is Poco X3 GT. China version may not have preinstalled GMS, Xiaomi stock firmware had disabled user installed GMS.
Qoo10 selling poco x3 gt 8+128gb at $388 with local official xiaomi warranty.
May need to pay gst and admin fee, need to check with seller how much they going to declare to custom.
https://www.qoo10.sg/gmkt.inc/Goods/Goods.aspx?goodscode=662838316
There is a review video of yesterday launched note 11 pro against note 10 pro/poco x3 gt. Note 10 pro has better fps for first few minutes of gaming then both about same performance after thermal throttling. However note 11 pro is slightly cooler and has much better battery life.
https://m.weibo.cn/u/2022252207
jazzz
Took a look at it, yes is indeed the same phone. Thanks a lot.
Krabs.
q001o hk seller restocked but is 338 not 300 july price
not that much reason to go for it since note 11 pro already out , just need to wait for global version or rebrand under poco
Shutterbox
meaning, dimensity chip is more efficient chip for general use?
Ctrl_Alt_Del
edit: after calculating the power used in mah, dimensity 920 is not most efficient, but still more efficient than dimensity 1100,1200
The battery life test of the phones under same condition shows that iqoo z5 sd778g is most efficient but should be iqoo optimisation, honor 50 pro sd778g power consumption is slightly more. Even redmi k40 and black shark 4 sd870 use less power than dimensity 920 in normal usage. However because note 11 pro has larger battery, it has more battery left.
However they test the phone without sim card, third party apps and only wifi. Real life usage may be difference due to telco signal and other third party apps.
The video has english sub.
Shutterbox
The battery life test of the phones under same condition shows that dimensity 920 is more efficient. However they test the phone without sim card, third party apps and only wifi. Real life usage may be difference due to telco signal and other third party apps.
with sim card n 5g antenna on, confirm will suck juice
noadaways, unless i need OTP or go out of home, i put to airplane mode at home.
reduce scam calls by alot, as well as conserving battery life :D
Ctrl_Alt_Del
My sim card got damaged after few weeks of scheduling the phone to auto enable flight mode while i sleep. Suddenly cannot detect sim card when i disable flight mode.
pigpigoink
wa according to this video so many people buy even before knowing the specs 🤣
amazingone
Now it seems like Redmi Note 10 Pro is out of stock everywhere, chip shortage is real :(
kazuki666
On the upcoming 11-11, I am thinking if can get a phone to replace my current primary day to day Poco F1. I am thinking between Redmi Note 10 Pro and Pocophone F3. I tried to compare them on gsmarena and their reviews, and seem that they are quite a close match.
Any user can advise what are the hits and misses I should take note if I am deciding between either RMN10P or F3?
Btw, I understand both also use side fingerprint unlock. Stupid question, if I buy a niilkin casing (the type which will cover camera lens), does it mean I won't be able to unlock the phone with fingerprint since the side is covered by the casing???
Krabs.
imo the F3 is a better buy if u don't need sd-card and 3.5mm jack ... because the rmn10p no discount while F3 is at historical low
alex22
Anyone's rmn10p can be used as a wifi repeater anot, how to enable this feature?
Not mobile data hotspot, but wifi repeater...
Ctrl_Alt_Del
While connect to wifi router, go to settings, portable hotspot to enable portable hotspot. You should see 2 wifi icons in the status bar.
kazuki666
I just notice RMN10P just went out of stock both on shopee and Lazada. Not sure if it was intentional or just "close" for 11-11
alex22
Yeah, that's what I used to do using realme hp but the rmn10p don't seem to allow this.
I try again...
Edit:
The device will repeat wifi only on the same channel as the source. E.g. When connected to 5ghz wifi will rebroadcast 5ghz during hotspot.
Cannot change the wifi output band unlike where mobile data hotspot is is employed...
My old Realme didn't have this limitation, so I thought my rmn10p was buggy.
Thanks guys.
Kennedy
can recommend RN10p tempered glass screen protector ? bought several online. they are slightly small, fit exactly to the display screen. I feel awkward looking at the screen. got a full coverage one which seems same size as the default installed plastic screen protector. they are right size ? I prefer one that covers the edges. thanks.
Krabs.
this is the lowest ever .... 318 -10shop -25bank or tech voucher = 283 .... only lose abit to 270 hongkong Qoo seller back in july
i skip because waiting for rmn11p
