Redmi Note 10 series
eip1234
Just updated to MIUI 12.5.9 which has the "extended memory" feature ... Can't feel much difference as yet ...
ZrE0_Cha0s
but then again will someone open more than 10~15apps at a go and left it open for 6 hours or more? i mean if anything will have to do with high ram usage normally isn't the phone OS rather than app? (even though that there some gaming app definitely want more rams thoguh.)
ThinkMe
My mom lor. She doesnt clear one.
i1magic
Till now, when say "Hey Google", the RMN10P still doesn't turn on.
There are a few times when I use the phone and the phone will literally "hang" for awhile. Got few occasion it becomes non responsive to the point that I have to press and hold the "power button" to reboot.
After checking out the Poco F3, which also has AMOLED screen, I am considering to switch.
tingsters
the hey google is not fuction.. to me..
i also dunno why?
for hang.. try to back up your stuff and try hard reset, see if it works.
matrix05
RMN10P with TPG. Do you need to download TPG 4G voice calling app to make /receive calls? VoLTE & VoWiFi are activated using the long string of code, but under settings, phone not showing any Volte option.
Other RMN10 phone shows Volte option under mobile settings, RMN10P's not showing or hidden somewhere?
i1magic
Don't need. But if sometimes, you cannot call out or people call and cannot get thru to you, then you can use this app to kind of "wake up" the line. Then people can call thru liao.
matrix05
Face TPG volte dailer problem? 1. Disable Volte using the *#*#volte#*#* code; 2. Reboot phone; 3. goto Settings-mobile network, the Volte option will appear, slide to enable.
TPG 4G voice dailer is not needed.
eip1234
Sadly the Chromecast or Mirrorcast functions still do not work well ... They were once working very well during the time of miui 10 and before ...
