Redmi Note 10 series
alex22
Any RMN10PRO user the VoWIFI like sometimes have sometimes don't have while on wifi at home or outside?
Mine like intermittent.
Anyone with the same?
mimicake
anybody knows if it's MIUI 12 problem or generally a xiaomi issue that you cannot batch delete contacts? currently have to tap the contact > tap upper right corner 3 dots >delete, which is damn leh ceh.
Searched on youtube, apparently there was an option to batch delete under system apps > contacts but it was for MIUI 11.
i1magic
I read an article that Redmi phones will NOT be using MIUI eventually.
matrix05
Note10pro. Camera can't play video after taking using the camera app to take video. Anyone got this problem & hv solution?
matrix05
U change the video encoder to h.265?
Use what to play the video?
Solved. Load in new video playing app (VLC) and update to 12.5.8 and it's alive again. Thanks.
Btw which apps are you guys using to play video? VLC, MX player or others?
ZhuTou!
if the spec leak is real , then rmn 11 series no more snapdragon cpu :s14: rumor is release before 11.11 in china
don't want mediatek :frown:
https://www.notebookcheck.net/Redmi...nsive-Redmi-Note-11-series-leak.573277.0.html
btw anybody know what happen to redminote10pro ? it's out of stock at sh0p33 and l@z@d@ official sellers , they accumulating stock for 11.11 sale or really stop production ?
Dimensity 920 ok leh can even play games
Better than mine 820
If price at 300+ is cheap
I wonder the camera have OIS anot lol
N10pro i guess chip shortage ba
techiesus
anybody use the colornote app here? i realized when i set the note reminder to "pin to status bar". it will be there, but once i kill all apps - the reminder on the status bar will disappear.
my previous xiaomi 9T phone not like that one leh. even if i kill all apps, the reminder will still be displayed on status bar.
i went to the app settings and have set allow everything. actually it's already alllow all notifications or something.
anybody else experienced this issue? how to go about doing it?
kottty
yes it will .reminder will gone is u kill it..only way is lock the APP so it will not be killed when u killed all APP..
Read HWZ Forum Rules!
alex22
I use colornote too but don't use its notification feature.
However my accubattery though locked, after closing all in background, the notification also disappear.
Reopen the accubattery, the lock icon auto there still and the notification comes back.
techiesus
totally forgot got this function. ya now it "works". thanks!
same thing with my colornote. like what kottty mentioned, you have to lock the app so when you close all apps, only accubattery is still there. lock the app by pressing the square, then long hold on that app and a few icons will appear - there's a lock, press it and voila, your notification will still be there
Kennedy
alarm bug or not ?
my rn10p ( miui 12.5.8 ) when turned off alarm set will switch itself on 6 mins before the alarm. same scenario, rn8pro 8 mins before the alarm. other older Xiaomi mobiles 1 min before the alarm which is normal. the two mobiles alarms ring at the scheduled time, it's just that they will turn on much earlier when turned off.
