Redmi Note 10 series
micey84
I wasn't considering Note 10s since it's older but at 8gb, I thought it should match up to those 6gb. But well, it does look almost similar for the other 3. Thanks for the input
Note 10s helio g95 processor is actually stronger than note 11 snapdragon 680 and 11s helio g96. Note 11 series this year in reality gives you less but charge you more. The same for all 3, I won't buy above $200 price range. If got discount good deal then can consider if not no need to chiong
idiot444
Seems like I should place my budget below $200 for these models in that case (y)
micey84
Simple rule of thumb: Take the phone models RRP and give it a 40% discount, that will be close to the lowest price you can get unless it is an extremely flawed model with lots of bugs and cannot sell. These models RRP range from 289-329, so value pricing to pick them up will be around 175-200
idiot444
Haha, the 40% off is a good benchmark on deciding if it's a good deal not
chaiscool
Thanks.
Too bad no more sale.
$299 not uncle budget .. :(
Wait for sale, poco x4 5G 128GB only $276 and poco m4 256Gb $289 before further coupon / coin discount on shopee.
All more worth it then $299 note 10
idiot444
while waiting for price drop, does the Poco M4 Pro 5G (6/128) with dimensity 810 fare better selling at $250 region?
waterballoon
it's a much faster processor. only trade off is it's an LCD screen but ain't too bad
underrated is that M4 PRO 5G' has good haptics for its price
micey84
Processor is decent and can handle most basic stuff well. I have used an older Redmi Note 9T with a similar processor albeit one version older (dimensity 800u). Used it for mainly shopping apps and livestream. Performance is good and battery life also not bad. Only con for this phone is at this price point, they give you a lousy LCD screen and you use it mainly to watch YouTube/videos, the screen is abit poor. I got it for about 165. Fair value for m4 pro 6+128 will still be around 200.
idiot444
Yup, I realised it too, with the use of LCD which is a let down. Monitoring price for National Day promo
idiot444
Gonna skip Note10s due to the 12nm chip which gets heat up easily I read, so this model seems decent, just need a little extra sale to drop its price ha
idiot444
Decided not to wait anymore. Bought a Poco X3 Pro, hopefully can last for next 2-3 years.
micey84
Good lah, X3 pro best value sub 250 phone, f3 best value sub 350. Now incredibly hard to find such value phones around.
idiot444
Unfortunately, I paid $280, but since it's still under $300, I can afford it, nvm la. At least learned some information over here from all you guys' input.
funky05
$200 for redmi note 10s is considered okay? Was using redmi note 9s but screen broke
FileZAce81
Hi, can anyone tell me how to export device contacts to sim card? Saw the option to import from sim card but don't have export to sim card.
For RMN10s
hk7310
For RMN10s
I have redmi note 9s, i think your xiaomi phone may be alike, if not please ignore.
May be you can try this:
-> Contact, at the top right, from Google contact/Mi contact change -> SIm, import from google contact/mi contact.
matrix05
Note 10;Miui13.0.9. Suddenly phone keeps getting "security keeps stopping" & "Find device keeps stopping" error msg. Then the phone auto reboot. Anyone same problem?
