Redmi Note 10 series
kopioking
Currently on promo, $209 onwards
https://shopee.sg/New-Arrival-POCO-...al-Official-Warranty--i.178877216.18838400525
For poco models, usually avoid buying during "normal" pricing. Wait for promo
I always thought that Poco is high end Xiaomi sub brand. Didn't know it can be so cheap. And the specs say that it has NFC so can use as credit card.
You are right must buy during special sale like 9.9 10.10. I bought a Note 10 pro recently (1+ month) @299 and it's 70 dollars cheaper than the listed @369 price. Or @40 cheaper than the retail promotion when it launched. Couldn't get it at the retail stalls which is already on note 13 I think.
kopioking
From official stores in shopee and Lazada, I think can claim 1 yr warranty in SG
The shopee 'official mi store' seller type me just walk in to funan Xiaomi with the phone and proof of purchase (screen shot). It seems that they can tell the batch of your phone from the serial numbers on your phone
kopioking
Hi all, am considering between Redmi Note 10s Vs Redmi 10C to get for senior citizen's daily usage. Which model is more suitable? Thanks for all advices and comments.
I use to think that seniors don't need better phone. But actually they need so because the higher end phone provide higher resolution and screen quality and brightness.
Setting to bigger text size defeats the utility. Set for them the triple tap and hold/two fingers tmagnify feature. Also if got macro can take picture of those small little words to read.
I am a old foggie
kopioking
Just bought a Redmi Note 10 pro from shoppee cos company budget only $250. Hope I made the right choice. Bought cos of the 33w fast charging n 6.67 screen.
Read HWZ Forum Rules!
1. when i bought it, it comes with screen protector already pasted. doen't look like very good quality but ok for me. Drop my phone a few times from 20cm height while falling asleep while holding the phone and still ok.
2. also there is a back transparent protective casing included in the box. quite good wrap over a little bit on the front of the screen.
3. if you are updating the os, make sure you have plenty of time on hand and the charger is ready on stand by in case you need it as the updating may take more than an hour. half way forcing it to reset will create a lot of problem.
4. must look out for global version and local warranty stated by seller
5. there is this Mi Mover app that you can download from Play Store on the old and new XiaoMi phone to transfer over the image/video/documents as well as app. But for the app it just transfer the apk installation files and in the end I still have to install myself so I just install my programs directly from google play store instead. If the old phone is not XiaoMi can also give it a try, should work if its android phone.
GReddy G9 RS
global version
and
local warranty
stated by seller
Thanks. Bought it from Xiaomi Global Official Store from Shoppee.
a4973
So my note 10 pro fingerprint unlock started to get slow. Took phone out of the case noted the back plate of the phone is lifted up such that I can see the adhesive, press down on the back plate it sticks for a few seconds then start to lift up again. Anybody else have this issue? Any idea is it swollen battery or maybe just loose adhesive? Thanks
funky05
Can I check.. the "cleaner" app in Redmi Note 10S, does it actually clean up or it's just useless?
a4973
Any recommendations for RN10P battery replacement? Got case of bloated battery just 3 months after warranty ran out.
tian_yibang
I just got 1 from xiaomi global and updated to 13 from day 1. so far no crashing,lagging and camera works..maybe I was lucky?
So many negative feedback, don't know to update or not. My Poco F3 on miui13 for quite a while also no issue but don't know on redmi. Maybe I'll just try my luck.
RN10P is alr 1 year+
coming to 2 years
by now it shud be stable enuf after all the updates
so if you just get the phone now and update it to the latest after unboxing shud be no issue
usually its after you use for sometime then update it will have issues
ie. there this whispers among ifone users that if theres no issue with current usage dun update aka 'if it aint broke dun fix it'
GReddy G9 RS
coming to 2 years
Ok, thanks.
