Redmi Note 10 series
amazingone
Never update your MIUI version too fast and furious, best to stay at the factory default version if possible. Usually the factory default version have the least bugs from my personal experience.
gundam77
Go for redmi note 10s.. during sales 8/256 goes for less than $200
Thanks funkypt for the advice. Saw yesterday on Shopee Redmi Note 10S (8+128GB) going for $199/- if I remember correctly... Didn't know there was a 8/256 GB version available but will keep a lookout for it.
Saw some comments to avoid this model due to its MTK chipset but to go for SD chipset instead. Was wondering if for senior usage (mainly watch YT videos, WhatsApp and MeWatch App), is MTK good enough?
gundam77
Redmi 10C has a bigger screen but lower resolution, if require larger screen then can go for that one. Other than that, Redmi Note 10S is the far superior phone.
Read HWZ Forum Rules on realme GT2 Pro
Thanks carboy00 for advice. Watch YT comparison between the 02 models and the clear winner was also Note 10S, unless need a bigger screen size, then 10C is the winner.
Redmi 10C runs on SD 680 chipset - better than Note 10S's MTK chipset? But this is only important for heavy gaming usages right?
funky05
Sorry my bad . It's 8/128
I've been using the phone for months, no overheat, smooth for apps and videos.
blue00
Still on miui 12.5.16.. I was advised not to update to 13 from those who did
open box my firmware was ice cool when playing light then after update 12.5 phone get hot when gaming
do u play games? i just play those puzzle block game
blue00
the screen is very clear n bright , in fact i m happy w my buy,
no problem when i watch youtube
only downside is smaller 6.4 think the poco c40 which is cheaper has 6.77 screen
funky05
I don't play games but I watch videos / movies. So far seems good
caterham7
Hi all, am considering between Redmi Note 10s Vs Redmi 10C to get for senior citizen's daily usage. Which model is more suitable? Thanks for all advices and comments.
Can also consider poco m5 or m5s, newer models, so launched with android 12
$189 and $209 during promo
Also have nfc if that is needed
blue00
Does the phone feels hot after 10mins video
Before update mine don't . Now the 12.5 update makes it hot at least I feel the heat just after 10min
Sausage
any way to disable the OTA update available message? To prevent accidental updating?
guyz92
Go to Authorization and revocation menu and revoke Updater permission.
This way it will block OTA update by blocking the Updater App from checking for the latest update.
kopioking
all over reddit I see people complaining of their 10s working fine on miui 12 and after updating to miui 13 freezing and crashing. anyone here experience it?
Read HWZ Forum Rules!
Only tip I learn is to set it to 60Hz refresh rate instead of 120Hz to prevent it from running hot. I don't use it to play game though.
And for the last two month I using it, freezes once. I just reboot. I upgrade to miui 13 from 12.5 when I started using the phone. I did it because I read that it will actually get rid of some of the bugs of miui 12.5
