Redmi Note 10 series
ZhuTou!
Xiaomi phone standard, always have cn and global version. If u cannot find using global model, use cn model to search instead. They are the same size/design. More variety to choose from.
amazingone
ZhuTou!
Don't think this applies for all models, like for example the Redmi Note 10 Pro global and China version are different in size.
https://m.gsmarena.com/compare.php3?idPhone1=10662&idPhone2=10930
It doesnt always be same name. It can be same specs model or same name model. One good example is k50 ultra and 12t pro. Another one is redmi 10x and redmi 10x pro. All using the same shape and size. The 2 phone u compare is totally diff phone. Only the name is the same.
Usually will have. Just need to search around. Some model are not that popular so its harder to find casing. So u need to search using the other model.
amazingone
Yep, usually will have similar models but named differently from the global and chinese version. In this case of @Janet90 she can't use this method as there's no identical chinese model of the global note 10 pro.
Janet90
Sweats it has been so long since I last brought Xiaomi. Brought this phone to be used for work… AliExpress ones aren’t to my liking… hence I went to taobao. Found what I needed. Thanks all !
funky05
Is the case from taobao cheaper than shopee?
Janet90
I customise mine…
Price wise if u had other stuffs then it’s alright to buy from Taobao since u need to factor in the shipment cost. Do take note that the 8% gst will kick in if your goods don’t reach spore customs bef 31Dec.
funky05
I customise mine…
Customise meaning? Putting your pic or own sticker design ?
SBS2716G
Any special setting to use this phone for MRT/bus ride ? Set up google pay app and no problem in tapping for payment at 7-11 but can’t tap for payment at MRT gantry.
Change the setting to HCE?
Any other special setting ?
hk7310
Any brother here has any difficulty in setting up your Wireless@SGx. I tried many times, still failed.
when setting up, at the hotspot area, i change the wifi setting of Wireless@SGx from PEAP to sim and save it. But the phone is not able to save it, after spinning awhile failed and back to the same page. How to overcome this?
funky05
What I do is, I deactivate my secondary SIM (if it's stil active), "forget wireless sgx" network and then try to connect again. I don't use the app. I use the WiFi settings direvtly
Another thing I noted is the rattling of camera when you place it on the table, feels like something is loose or poorly assembled internally.
Is this an issue with all Note 10 pro?
Mine also have this rattling sound when placing the phone on the table. However, when shaking the phone, no rattling sound at all.
