Redmi Note 10 series
FloatingBarb
Not exactly? In the example of Note 11, I read the general consensus was that note 10 Pro was better.
Was curious if anyone knew more about the technical specs of the Note 12 and its launch date for the global ver.
One commentor mentioned it might be released in the next 1-2 months.
Johnringo
PSA redmi note 10 pro on qoo10 stacked with vouchers at $208.
I wanted to buy from official store but camp at midnight and dont seem to have stock despite the 12.12promo of $269 for 6/128g
a4973
Hi the qoo10 offer looks like great value. Mind sharing what are the vouchers to get and stack and are these vouchers in limited supply? Thanks 🙏
amazingone
Anyone fixed broken screen glass at Xiaomi service centre before for Redmi Note 10 Pro?
ZhuTou!
Can try buy from aliexpress fix urself. Buy the glue as well. Usually xiaomi phone replace screen is not worth it. Might as well buy new phone.
amazingone
they fast one. after u pay tmr can collect. if phone more than 2 years and u plan to use longer, i suggest change battery together for like $30.
note 10 still decent.
Yea still a decent phone so it's a pity to throw it off just for cracked screen. Do they require you to factory reset your phone before sending to them?
funky05
Was using it naked then slipped off my hands and the phone edge went direct to the ground. Instant spiderweb crack and I was still using the pre-applied screen protector which didn't helped as it was just a plastic film.
Alamak... Hope your phone can be salvaged.. my friend dropped his phone during his holiday at Penang .. went to some ah beng HP shop to change screen RM300.. done within an hour.. no data loss
Janet90
Anyone know which model of case to get from Taobao? I have gotten 2 but they don’t seem to fit the note 10 pro.
amazingone
Did you get the one that is for global version (國際版/港台版) or for the China version? Our local note 10 pro is the global one.
