Redmi Note 10 series
tangkh
Hi everyone
Recommended Redmi Note 10 Pro to my Auntie because she was previously using Redmi Note 5 and prefers to keep to MIUI. Bought from Lazada Xiaomi Official Store Global in October 2022. Backup and restore from her Redmi Note 5. Since then she is complaining the screen turns off when she is doing a phone call or Whatsapp voice messaging even when she is not holding the phone to her ear.
I did a Google search and found that it may be due to the proximity sensor. Xiaomi acknowledged the problem in 2021 and said it will fix the bug with MIUI update.
Already updated to MIUI Global 13.0.14 Stable and the problem persist.
Did a proximity sensor test in CIT. Test value 5.0 with and without covering the top half of the phone with my hand.
Does anyone here have the same problem and have it resolved or should I pay a visit to Xiaomi service center?
Thank you.
hk7310
What I do is, I deactivate my secondary SIM (if it's stil active), "forget wireless sgx" network and then try to connect again. I don't use the app. I use the WiFi settings direvtly
you try put sim card on slot 1 only, see if wireless sg setup can work.
Thank you all, brothers
No change to the SIM card in slot 1, but wonderful happen when I were having my meal at McDonald, it connected.
tangkh
Hi
Can any Redmi Note 10 Pro owners help me to do a proximity sensor test on your phone?
Click on Settings and tap About Phone. Scroll down and tap several times on Kernel version until we get to the CIT menu. Scroll down and tap Proximity sensor.
Check result is 5.0 when the top of the phone is not covered and 0.0 when it is covered.
Thank you.
funky05
Hi
Thank you.
Yes results 5 and 0 on redmi note 10s..
SBS2716G
Can anyone confirm that the global version cannot use the “xiao ai” app?
Seem like it is only for the CN version?
tangkh
Hi everyone
Thank you.
Hi
Thank you.
Thank you for checking. Maybe this warrant a visit to Xiaomi service center
pigpigoink
Hi
Thank you.
i tried on both 10 pro and 10. didnt change to 0, but during normal call screen will turn off when facial is near, which means its working lol
tangkh
Thank you for checking. I am puzzled why the proximity test result is 5.0 on Redmi Note 10 Pro and Redmi Note 10 but funky05 is able to get 5 and 0 on his Redmi Note 10s. I believe all are using virtual proximity sensor from Elliptic Labs.
Background
My Auntie's Redmi Note 10 Pro screen turns off when she is doing a phone call or Whatsapp voice messaging even when she is not holding the phone to her ear.
funky05
Background
Can ask her try using earpiece while on the call, see if screen goes off. Try speaker mode too.
I think if go back service centre, not sure if they'll reformat data
Anyways for me the issue I had was when I answer or make calls, after a few seconds it will auto press mute button.. found it quite irritz, but managed to resolve by itself by the time I find time to go service centre lol
tangkh
Thank you for your suggestion. I don't think she likes to put things into her ears :)
While searching for solutions, I came across a thread in OnePlus forum about WhatsApp voice note | Display turns off.
Quote
"WhatsApp voice note | Display
turns off
May 12, 2020 08:42
I am having a really annoying issue with my OnePlus phone. whenever play a voice note, the screen goes black and voice note stops playing. I had to retry unlock.. and the worst part is when I try to unlock the display comes and goes off immediately. this issues Occurs 75% of time. and while use my phone lying it happens always. haven't experienced in any of my previous phones...
pls help."
"It happens because OnePlus battery settings limit WhatsApp from running in background. The minute screen goes off, the battery settings disconnect WhatsApp. Solution: Click on your phones settings, then Scroll down to Battery, click on battery. Now look for Battery Click on it and scroll down to find WhatsApp.
Click on WhatsApp and check the options. Mine was on ootimisation, when it should be on Intelligent Control. just choose the 3rd option Don't Optimise, and my WhatsApp voice calls are working ever since. found that under Battery Optimisation setting, the Phone, Signal and Telegram, all were on Intelligent Control and they were working fine. Why OnePlus team decided this Optimisation setting for WhatsApp, the most used app is beyond my thoughts. But this has certainly caused numerous issues with a lot of users and no solution. Any other model and make, please check your battery saving options. They may use different names for Battery saving option. Cheers
Raj
Dec 13, 2022 02:40"
I will try to change the battery setting for Phone and Whatapps to see if it fixes the problem when I next visit my Auntie.
hlw8888
hi all, anybody here a user of redmi note 10 5g phone? currently using redmi note 8 pro, still working well, juz seeing if note 10 or 11 is in any way better than my current one?
caterham7
FYI redmi note 12 models already passed through IMDA certification
https://eservice.imda.gov.sg/tls/searchEquipment.action
meaning may be available locally soon
if not in a rush, can wait to see if rmn12 series is a better replacement for your rmn8pro
