ZhuTou!
- Oct 6, 2008
If someday u drop phone and the screen is facing downpersonally for moi, moi just use the default(case and already pasted screen protector)
Good luck
Hows the phone?confirm chop. just setup too
lol ya lo the risk is there, but just make sure no dropIf someday u drop phone and the screen is facing down
Good luck![]()
also haven't play yet, got iphone 12 pro and note 8 proHows the phone?
Good bo?
I haven play yet
moi too lol!I havent bought from Qoo for very long timebut thanks
I normally buy 2pcs as standby. Anyway, so cheap.No matter how ex is my phone
All use cheapo TG one lol
Still well protected, phone drop TG broke but phone is ok
Just buy 1 pc extra keep can liao
2pc is like $2-3 only
Yes, I used penknife to peel the edge off then remove it.Thanks all.
Easy to remove the old one?
use a pen knife?
Yes. Those cheap TG SP has saved my phone screen many times liao, except the last one. But that is because my phone dropped from my phone holder on my bicycle and then my rear bicycle wheel went over it in Coney Island.If someday u drop phone and the screen is facing down
Good luck![]()
China version. Different rear outlook, different cpu, china rom.Didn't know Note 10 pro comes with Corning Gorilla Glass Victus, not sure if this is a new version since they have many variants.
https://www.notebookcheck.net/Xiaom...-Glass-Victus-through-its-paces.541662.0.html
Helio chipset ish cannotHands-on review of Redmi Note 10s...
https://www.gsmarena.com/xiaomi_redmi_note_10s__hands_on-review-2268.php
Why?Helio chipset ish cannot![]()
Actually, I feel that Helios SOC is quite good.Helio chipset ish cannot![]()
Review say its performance similar to sd678 so might as well choose sd betterWhy?
If compare to n8pro, n10pro battery should be better and lesser heatActually, I feel that Helios SOC is quite good.
Frankly, now after using the RMN10P vs my old RMN8P, not much difference.
I mean the day to day usage feels quite the same leh.If compare to n8pro, n10pro battery should be better and lesser heat
N10pro is oled screen and camera is alot better
N8pro is old school phone liao, update gonna stop sooner or later
Simi no diff
Its so big diff![]()
