Redmi Note 7
xonix
Xiaomi Malaysia posted on FB, coming soon price under 1000 MYR
I think the Pro version won't be sold in this region because of the price difference to Pocofone F1.
Several HWZ forumers have already posted that they won't consider N7 Pro if they can get F1 for just a little bit more.
davidwong
That’s why xm market segments n marketing very jialat
1a) Mi 9 - 750 onwards
1b) shark 2
2a) Mi 9se - 630 - 748
2b) Mix3 - ??? - 748
3a) unannounced Redmi flagship?
3b) Pocco F2 - 550 - 650 (maybe the same product as 3a)
3c) MiMax4 450 - 550
4a) Redmi Note 7 pro 350 - 450
4b) Redmi Note 288 - 348
4c) Redmi 7 238 - 288
davidwong
Haha those pricing are my guess only becos xm is a listed company so pricing will surely gies up also last time no big screen now we have nite 7 so in order to value add thinking better screen n cam.n even rumored nfc
So expensive for max4? I got max3 for 270
Sent from Xiaomi MI MAX 3 using GAGT
takagen
Nope. Gave up on trying and used my TPG sim on my Mipad.
Thats why still waiting on global rom to see if it works
I've finally got data working on EU rom, so sharing it here see if it works for you.
1. In dialer, key *#*#86583#*#* to disable the carrier check, which in turn will enabled VOLTE call. (this step probably not required)
2. In APN settings:
> APN Type input as "default,supl". This setting was the only thing that i've updated, which actually made it work.
> The rest of the other values were actually system defaulted
> Refer below
tomsss
2. In APN settings:
> Refer below
Wow it actually does work! Thanks!
BTW does your GPS work properly?
carboy00
Wow that's good, anyone with note 7 pro and tried and works?
Redmi Note 7 Pro only just went on sale yesterday in India, the only market it is available in now. China's announcement only happening next week. Will take a while before anyone can get a unit. :s13:
jonathanljk
Can anyone enlighten me on the difference between China rom and global rom? Intending to get a set for my grandpa to use whose usage solely consists of texting and calling.
I have actually ordered a oppo ax5 for ~$170 and was wondering whether the note 7 is worth the $40 top up for the sd660. On the other hand the oppo comes with 2 years local warranty
Thanks in advance!
limjialok
Thanks in advance!
Yes, ax5 uses Snapdragon 625 I believe and 660 is like close to 2x the processing power of a 625
kazuki666
