Redmi Note 7
kazuki666
Actually until now I am still confused about getting China sets which come with China ROM. Is there a fixed rules which model can and cannot be flashed to global rom after that? Because for example RMN7 China sets have few versions, while India and other countries don't carry all right? I scare buy a particular China version wait can't flash to global ROM.
I saw in miui forum about first step to unlock, second step is to flash the selected ROM be it global stable or developer. Correct???
Sent from Xiaomi REDMI NOTE 4 using GAGT
Project_Xco
Note 7 and pro using emmc 5.1, Poco using ufs 2.1 , mi8 lite can't seems to find any info but most likely emmc 5.1
I think redmi note 7 Pro uses ufs 2.1 while note 7 doesn't.
https://www.androidcentral.com/redmi-note-7-pro-specs-48mp-camera-snapdragon-675-quick-charge-40
xonix
Yeah , ufs 2.1 is very important. I rather have a slower sd636 w ufs 2.1 than a faster 660/670 with emmc 5.1. it's like desktop i7 with HDD vs i5 with SSD all over again
I have have had a SD821 and SD660 with emmc5.1 and didn't feel slow to me. Of course, UFS would be faster but emmc 5.1 wasn't impeding my daily usage. RN7 is a "budget" phone after all.
Of course, if one was loading large files ( i.e. games ) frequently, then it would be different case altogether.
davidwong
Ya I was aiming for China pro hence wondering is it room compatible with global pro
tomsss
Currently I'm using the 64gb rom/6gb ram version from China and had successfully flashed a EU rom version (which is a CN rom version but without the China bloatware).
However, now I have issues with the supposed global rom that was release a few days so.... Can flash the rom no problem, but one I restart my phone it keeps popping this "find device closed unexpectedly" message many times and then phone reboots to recovery. Did a factory reset and clean install also cannot. Sian. There is a fastboot rom version but that link is down and many say only that fastboot rom version then can work properly.
Now I trying to flash an updated eu rom version to see how.
You may wanna hold your buy first
davidwong
That's the issues I can having hence the teeth dilemma of having it affordable but kits if diy vs overpriced but hasslefree
kazuki666
I was looking Mi India website, they seem not carrying 6gb ram version. This is why I was worried if there is hardware restrictions when flashing global rom...
tang_tang
Only china set will face this kind of problem is it? Buy local set and pay a little bit more ..wun be so maifan and face gps problem correct?
dryteletubby
Seems now can't really flash a Chinese OEM phone to global ROM easily?
The last miui phone I flashed was the redmi note 4g and changing it from Chinese to global ROM was straightforward.
If flashing ROM require unlocking of the bootloader I think I wait for the local version.
tomsss
Yes local set would be less of a hassle... for me I'm ok with getting China set as I have some experience in flashing Android phones and rooting. Also this experience let's me explore the vast customization available.... The last Android I had was the Samsung note3! =:p
Audiology93
Yes if wan to flash from China to global rom, you need to unlock bootloader. Usually 360-720 hours of waiting.
Sent from HUAWEI Mate 20 using GAGT
amazingone
Redmi Note 7 Pro and Redmi 7 China launch event will be happening later at 2pm, stay tune :s12:
Posted from PCWX using HUAWEI ALPS
davidwong
Anything we need to look out for note 7 pro or is it the usual fanfare and concentrate more of on redmi 7 instead?
