Redmi Note 8
KalTorak
not the pic. need to cart to get actual price. hahah.
edit: cheapest color now 168 but cant apply qoo10 vouchers zzzzz.
Time sale @ $168 now also can't use vouchers.
Use Qcoin/Qpoints/Gift card/shopback/rebatemango/CC rebates/etc then.
KalTorak
Seem like this is the cheapest buy in this sale
$369-$35coin-$5-$30citibank=$299 @Lazada
Sent from Amazon using GAGT
Wah, if include coins then Shopee deal I posted before is $338-$31voucher-$10coins=$297 @ hitecmobile
Anyway, you hoot the Redmi Note 8 Pro already since Realme XT no more promo pricing?
Pocoyoz
Haven't hoot .:(
KalTorak
Can't find that mimi store. Trying to get the cheapest note 8 pro from shopee (have $30 voucher) or qoo10 (i have $50 voucher). Laz no voucher
Skip that store, overseas seller claiming 'Local Warranty'. Rather get global export set from local seller with 1 mth shop warranty.
If you have a lot of shopee coins, can get from hitecmobile.
Otherwise, its $308 from RMW on Qoo10 (after shop+cart coupon).
This is for the Redmi Note 8 Pro 6/128GB (1 yr Local Xiaomi Warranty).
Although if you want the LOWEST price would be global export sets.
https://shopee.sg/Xiaomi-Redmi-Note-8-Pro-(6-128GB-64GB)-Global-Version-i.146144985.4302034484
Redmi Note 8 Pro 6/64GB (Global export, 1 mth seller warranty) @ $261.05*
Redmi Note 8 Pro 6/128GB (Global export, 1 mth seller warranty) @ $284.81*
*Prices from shopee after $31 voucher, before applying shopee coins (if any).
KalTorak
I found a link on XiaoMi Singapore FB page that links to Shopee "MiPreferedStore"
Yes, that is Xiaomi SG ONLY authorized official store on Shopee.SG
https://shopee.sg/mipreferredstore
The ONLY other authorized online store is on Lazada @ https://www.lazada.sg/shop/mi-store
EDIT: There is also another Lazada store @ https://www.lazada.sg/shop/xiaomi-certified-store
The URLs above can be found on the official Xiaomi SG FB page.
this 168 is from Finer, right ? Meaning must ship back for repairs, right ?
Yes, apparently seller (Finer) will bear the postage for any warranty claims.
Plastick
kana self-owned sia... before the whole time sale thingy with my voucher should have bought already. coz now the overall savings not as good as before.
TechNo0B
For those who have flashed their CN ROM and installed Global ROM, I'd like to ask, what's the difference when flashing and selecting "clean all" & "clean all & lock" in flashing process? Seems an unlocked bootloader cant use some banking apps... So can one flash and select the latter option and the banking apps can work?
Audiology93
Don't lock the bootloader after flashing. It will brick your device.
https://www.reddit.com/r/Xiaomi/comments/b4phic/migrate_from_chinese_rom_to_global_rom_on_almost/?utm_source=amp&utm_medium=&utm_content=post_body
Sent from Xiaomi MI 9T PRO using GAGT
eting72
https://www.reddit.com/r/Xiaomi/com..._source=amp&utm_medium=&utm_content=post_body
yes, don't lock....that was how i bricked my max 3 :(
NightRaven49
yes, as those have mentioned above, relocking bl on cn set with global rom will brick. if u want to use gapps and banking apps, u can either
1) leave it locked on cn rom and manually sideload gapps
2) unlock, flash global and magisk
the latter will give u root, but can be a bit daunting if u never mod ur phone before.
