Redmi Note 8
cscs3
Just received a parallel set from Lazada. Global ROM, India set. No call recording as it comes with Google message and dialer.
See my previous post. If you are coming from old Xiaomi phone and you has backup with Mi cloud. Mi Dialer, message is restore as part of the restore process.
PeasantBeing
Obviously you are wrong!
Please check Miui community before conclude.
The wrong one is you.
Default global set comes with Google dialer and Google messages app. But to save your own face you keep insisting that the global set has call recording feature.
The forum links which you provided already said the restoration method won't work as the MIUI apps restored this way will give errors and force close.
Sent from REDMI NOTE 8 Neptune Blue using GAGT
limpingsim98
1. As long as you are previously on Xiaomi Global (before Android 9), you will be fined when you port over to new Xiaomi phone in term of dialer and SMS message. However, suggest not to use Mi server to assist in sending SMS. Turn it off under message setup menu.
2. Limitation of recording function on Google dialer (for country privacy reason) will be restored early next year.
3. If you have China rom and side load Google play. Check play store-setting you may find your phone status is "device is not certified". You may have problem with banking and payment application.
4. If you unlock bootloader and flash global rom to phone with China rom, you cannot lock bootloader again as phone may go defect. Phone with bootloader unlock may have same issue as "3".
So be very careful when flashing rom. Also suggest you make use of Google cloud or mi cloud to back your old phone then restore to new phone.
limpingsim98
This is only applicable to phone ship with Android version 9. If you restore your setup from older Xiaomi phone, you get dialer replaced back to Mi dialer (plus message and contact). This is mention in Xiaomi website.
If you are first time Xiaomi user. Download the apk from Xiaomi community or with till Google has this change by early next year.
Long time Xiaomi user likely did not know the different as they probably restore setup from backup.
cscs3
When you get a new phone, restore step is at 4th or 5th option after you have setup WiFi. Rest is wait for process to complete.
chesterqw
Need call record just download app lar wa Lao.
Simple thing dunnid argue.
This is Android not iOS.
FloatingBarb
Hi,
I see the Redmi note 8 has NFC. Can i confirm if it will allow paywave payments with credit card or allow one to pay the MRT gantry? Similar to apple phones of Samsung phones?
Thanks in advance.
NightRaven49
Hi,
Thanks in advance.
normal non pro note 8 does not have nfc. note 8 pro and 8t have.
but yes, so long as have nfc, means can use google pay for credit/debit card and public transport.
eting72
hi gurus,
i currently have a set with cn rom 10.38, can i flash it using a fastboot global rom 10.32?
if not...i can't seem to find the latest fastboot global rom. any kind souls can help direct me?
PeasantBeing
hi gurus,
I got the latest fastboot rom from Mi Global Community c.mi.com
Sent from HUAWEI EVA-L19 using GAGT
eting72
can I know the version? can only see global ROMs but without fastboot...
Sent from OnePlus HD1900 using GAGT
limpingsim98
hi gurus,
You need to unlock bootloader first. AND you cannot lock it back after flashing to Google rom. So think twice as Google play store will flag your device to non certified.
bomberman
i've got mine thru apex as well..
it is White Box Global ROM set.
I believe it is EU set, but unsure.
Comes with 2-pin EU plug 18W charger.
good stuff...
sHiErShAo
$25 S h o p e e flash voucher up for grabs!
Redmi Note 8 Pro 6/128GB (Local set) @ $244* from eventsapex
Redmi Note 8 Pro 6/64GB (Global export set) @ $220* from univercell
*After Shopee/bank vouchers and 1k coins.
Still available for this promotion? Can provide? Thank you.
KalTorak
No more...LOL!
Those prices were after $25 shop.ee voucher, $20 bank voucher and 1k coins.
The upcoming 12.12 sale only have $12 off bank voucher, not sure about other discounts.
So I doubt will have such low prices again.
You can try getting from Laza.da instead.
