Redmi Note 8
lonestar86
My preference is that I won't upgrade if my phone is working fine (working and not too slow). Only thing is that if the phone breaks down and I need to get suitable phone immediately to replace, then I may not get the offers. So if you can get a standby phone and tie over the period, then can wait.
Unless you want a new feature like NFC, or 2 SIM + SDCard, etc, then even if the phone is working, can switch.
My redmi 5+ is still working fine but after the most recent update, i noticed there is a slight lag and the batt life took a hit as well so i am wondering if it is time for an upgrade.
I don't really need NFC but it is a good to have function.
No such thing as worth it or not from 2 users. Everyone have different view and willingness to spend on gadgets. Same as why some find iPhone cheap and justified.
This is so true hahaz
GoodBetterBest
Some updates give problem. Subsequent updates will clear the problem.
wongminmin
For people who buying..
univercell via shopee
-free wireless headset
-free phone ring holder
univercell via lazada
-free tgsp
-free tpu case
lonestar86
I think I may be upgrading from my redmi 5+ to note 8 pro cus the specs r just too good for its price!
Anyway, side track a bit. Anyone use mi mover before? I know it could copy everything from the old phone over to the new phone. Even existing whatsapp/telegram chat? Is there still a need to backup and import the chats into new phone?
TIA!
NightRaven49
TIA!
telegram there is no need to backup for most chats except for secret chats.
hkchew03
TIA!
Mi mover is not 100%, some app might not be carried over due to compatibility or what. Just do a manual backup first
Posted from PCWX using MSM8998 for arm64
tingsters
TIA!
mi mover is not 100%.. not all the things can bring over to the new phone.. unless all the h/w n s/w spec is the same then is 100% if not nope..
whatapp u backup it to the cloud can liao.. later u restore from the cloud...
bomberman
so whats best way to transfer from an older xiaomi phone to new one?
reinstall apps one by one?
hkchew03
Just use mi mover, those not copied over just do manually. Should at least copy over 80-90% of the app and pretty much fuss free. mi mover also copy your media as well.
lonestar86
Ok thx.
Will do. Thx.
Thx for the info. Will use mi mover.
yh_lee
May I ask comparing redmi note 8 and Mi A3 , which is a better phone to get? Thinking of getting one for my daughter going Sec 1 next year but not sure which to get. Thanks alot
