Redmi Note 8
Audiology93
~$195 for 3+32 after GST refund.
Sent from Samsung SM-N950F using GAGT
Pocoyoz
Why Swipe up home screen change change to chrome. Mi browser always pop up.
Sent from Amazon using GAGT
Pocoyoz
6/128 S$300. Can fight note 8 pro?.
Pocoyoz
is realme camera better than xiaomi?
realme
Realme 6 is coming in 64GB and 128GB UFS2.1 storage versions and both get a dedicated microSD slot alongside the dual SIM Slots.
On the inside, there is also a 4,300 mAh battery that could be charged in one hour with the 30W charger in the box.
64MP main one with Samsung ISOCELL Bright GW1 sensor, 8MP f/2.3 ultrawide unit, 2MP dedicated macro shooter and a 2MP B&W auxiliary unit for enhancing the portrait shots.
64 MP, f/1.8, 26mm (wide), 1/1.72", 0.8µm, PDAF
8 MP, f/2.3, 13mm (ultrawide), 1/4.0", 1.12µm
2 MP, f/2.4, 22mm (macro), 1/5.0", 1.75µm
2 MP B/W, f/2.4, (depth)
16 MP, f/2.0, 26mm (wide), 1/3.1", 1.0µm
redmi
64 MP, f/1.9, 26mm (wide), 1/1.72", 0.8µm, PDAF
8 MP, f/2.2, 13mm (ultrawide), 1/4.0", 1.12µm
2 MP, f/2.4, (macro), 1/5.0", 1.75µm
2 MP, f/2.4, (depth)
20 MP, f/2.0, (wide), 1/3", 0.9µm
camera about same:s11:
https://www.gsmarena.com/realme_6_hands_on-review-2078p3.php
gsmarena hands_on-review
carboy00
Initial reviews of the flagship X50 Pro 5G don’t really have good comments on the camera and that’s their flagship. The previous X2 Pro camera wasn’t as good from reviews too. With their flagships having not so good cameras, not very confident about their lower end models. Just hope it’s getting better down the road via software updates.
VeryCoolDude
Anyone have a exported note8 set? My gps seems not able to function properly. is it because of the rom?
Posted from PCWX using Mi 9T
GoodBetterBest
Check with those who recently bought 8 Pro from the online Global Store, have you upgraded to MIUI 11.0.6.0 ? Do you have a problem with your NFC ?
Thanks !
GoodBetterBest
NFC not working for me after 11.0.6
But it seems working for many ppl on this forum
Where you got your phone ? Local ? Global Store ?
I also saw some people complaining on the XiaoMi Forum.
Need to submit bug report using the feedback on the phone. I think more people submitting, they will raise the urgency.
hellscream
Shopee. Then I manually downloaded the 11.0.6 to upgrade
NFC stopped working after that
GoodBetterBest
carboy00
I OTA. If ok, submit a bug report. Hope more people submit, the patch comes sooner.
The global store, right ? I wonder if it's those phones from Shopee Xiaomi Global Store.
https://shopee.sg/xiaomiofficialsto...8vGUHYnrWcPjvmkVqTODjWOAPtqQm45bZ0U6svkZEmYGc
Anyone bought from there, upgrade and is OK ?
I gotten my Ocean Blue Note 8 Pro 64GB from this seller. Upgraded to 11.0.6 and NFC working fine but had some issue with my network (stuck on H+ and not 4G) the past few days, factory reset my phone, redid GPay, tried it to pay at McDonalds and it works.
